Mehusieni
So, I went to local track while it was closed to take some pictures with my friend. As I was coming towards him while spinning the rear tire on the dirt with maybe 1/4-1/2 throttle, the bike just died. Thought I've blown a fuse or something, because it just died. No mechanic clatter or rattle sounds came from the engine. Tried starting it again and all I could hear was clicking from the electric starter, but it wouldn't even spin the gears. We tried to push-start the bike, but the rear wheel would just lock-up every time.
After a while we went get my friend's trailer and loaded the bike up. On the trailer I noticed it was dripping oil from a hairline crack in the left half case next to the stator cover. Seemed like the counter-ballancer or something hit the case.
WARNING,
THE PICTURES YOU'RE ABOUT TO SEE MIGHT BE DISTURBING TO SOME PEOPLE, PROCEED AT YOUR OWN RISK!
Popped the head and cams which seemed fine. The cylinder was a b*tch to get off, but revealed this...
Found some discolored pieces of metal inside.
The conrod is cracked at the bottom and bent. That small square at the bottom is the counter-ballancer. CAN THE CRANKSHAFT BE REUSED IF I TAKE IT TO A PROFESSIONAL TO CHANGE THE CONROD AND TRUE IT?
WARNING,
