125-200cc Case split for crankshaft repair, what else to change while its open.
Justus
Hi,
I am repairing my WR360 for 1999. It has a scored piston and crankshaft bearing damage.
The case is allready split and all the gears out. They look fine, no marks or (excessive) wear there.
Now that the case is split: what is smart to change as well? What bearing, etc.
The crankshaft bearings will be changed in any case.
What is the advice here?
I could really take some pointers/advice here.
Thanks,
Regards,
Just.
Hi, these engines are very good, just normal maintenence, check bearings, water pump seals, all gears and con rod clearance, clean the exhaust valves..
If you need any kind of parts please let me know.
Thanks,
Edgar Carreira
ECBIKE.PT
