Case saver?
Motoduc84
Looking for a case saver for a 1982 WR 125? Checked with Chuck at HuskyJunk.com and his model won't fit.
you mean then what we call the counter shaft sprocket cover. It does have a unique bolt pattern unlike the other models of Huskys, which are all the same. Just plastic so how much case saving it does is questionable. Many "case savers" ar either dirt/mud/vegitation clogs or worse yet compound damage done if chain simply derails (i.e. most noorioius setup being those horseshoe shaped ones that arch around foward side of C/S and merely serve as a bolted on piece that gets forced out and the bolts wont break so the take the case thrads and a good chunk of case with them when they finnally let loos after the chain gets foced out of he way and it has to go somewhere...it is simple physics. The "good idea fairey" was behind that design for sure!
UpTite didn't have one. George suggested riding without the cover would save the cases. Would still like to find something, though...
