mattmcphail
Hey guys.
I found this bike on craigslist for $125. I figured it would be a good bike for a first attempt at a rebuild and good chance at a learning experience to help with my very weak mechanical skills.
I'm DEFINITELY going to need to rely on you guys for some help.
After a lot of research the I found out that the bike is an 89 Cagiva 250WMX. I know I'm a year out of the "vintage" cagetory hear, but I really wanted to put this in the restoration section. Engine parts are going to be tough to find but I talked to Hall's and they along with other dealers still ahve most parts I'll need.
Upon first inpection the bike looks rough, but most everything is moving freely and most all parts are there. The only missing parts are the carb and the piston. It had previously been taken out when the motor froze. The forks aren't correct as it originally had USD forks. I plan to leave the conventional forks just to miinimize the build cost.
This is what it looked like when I picked it up.
So far I've stripped the bike down and the only thing that seems to need obvious replacement are the rear break pump / cylinder and the front brake lever and resevoir. They appear to both be rusted out and shot.
I stripped the frame with and aircraft stripper 2 times, and then wire brushed it with the drill.
After 2 coats of primer
This was about 4 coats of Duplicolor "Deep Blue" with the hvlp gun. It was the closest that the auto parts store had to the original blue. It's a little too metalic but it looks pretty good.
