Brembo
John47
Brembo rear master cylinder, just a heads up, mine went to the floor in the Wyoming National. With some time on the bike the seal inside the Master cylinder wears a hole in it, and you loose your brakes. Same problem with KTM. same master cyl. Easy to change the seal but hard to prevent the problem. Mine is a 2010 TXC 250.
