aluminium chunk in sump
pensy
I have recently bought a 08 txc 510 with 170 hrs, when i pulled the sump screen out i found a small piece of aluminium about twice the size of a match head, it nearly looks like a piece of gear tooth although I can t see any machining marks. Was hoping someone might be able to tell me of any internal aluminium gears or other ideas as I can t seem to see much in the black and white manuals and have never had these motors apart YET!! Surely the starter motor pinion or any other gear under load is steel.
Any comments appreciated thanks
The only thing that I can think of that would be made from aluminum inside the engine case would be clutch related. I defiantly would not ride it until the source of the chip is found...
