250-500cc AC⚡DC
Birky_41
So after owning the bike a few months firstly the dash decided to pack up. After a bit of research I decided on the trail tech endurance 2 which so far has been brilliant
I went into a special mode and put the correct miles and hours the bike had done and then calibrated the Speedo. At 70-71mph on dash Google maps GPS reads 70mph so real pleased with how spot on I got it
Next plan was to get power to my phone and let it charge when riding (or anything else to that matter) as I have a quad lock and often use maps by byways, trails and green lanes
The issue is it's AC and I needed something simple to give it DC power. Id already removed the indicators and changed both the side light and main to LED which was both a lot brighter and energy saving
Next was to work out what the bike roughly produces in wattage - turns out to be about 80-85w
I only really needed 3a or about 36w but I bought an AC to DC converter at 5a or 60w which was more than enough and still would have enough for the trail tech dash (< 1w) side bulb 4w, brake light 5-10w and main light 18w
I thought I'd make use of the ignition blank and after a bit of oversizing it fitted the USB plug perfect
I ran the converter off the side light so it only works when I need it and have lights on rather than always running
Tested and it works great!
