White Husky
Hello all
I took off my clutch cover to replace the O rings on the gear shaft (the shaft sticking through the clutch cover that the gear lever attaches to).
On replacing the clutch cover, I carefully aligned and located the indented slot in the shaft with the raised profile in the gear 'kicker' (that's what the parts manual calls it). Fiddled around for a while to figure out how to locate the kickstart shaft onto its gear. All went back fine, but now the bike (which was in neutral) will not select a gear. I have tried spinning the back wheel, and have had the clutch case off again to move the kicker manually.
I haven't refilled with oil yet, but I can't see that that could be preventing the bike from selecting a gear.
Has anyone experienced this issue when removing and refitting the clutch case?
Thanks
Lucien
Thanks
Lucien
