squid on a 300
I started working on the 79 CR 250 I picked up at mid-Ohio in July. The engine is locked up. After soaking it in the frame with PB blaster for 1 month it still would not budge. So I took it out of the frame and pulled the head. Luckily the bottom end was free so I was able to lift the cylinder and begin soaking the piston from the bottom. Tried freeing it with a 1x1 and a deadblow hammer to no avail. Then took a metal bar attached it to the studs and put a socket between it and the piston. Cranked it down pretty tight and wailed on it with a framing hammer till it moved. Soaked it some more and pressed it out with the same jig my increasing the height of the sockets as the piston moved down the stroke. Pressed the piston pin out earlier today. Shop manual has been ordered.
I will be splitting the cases in the next few weeks. This will be my first time doing a bottom end and tranny. My intent with this rebuild is to do as much as possible (exclusive of machining work) myself including rebuilding the rear shocks. Thanking you guys in advance for advice and answering what may be some dumb questions. My goal is to have it ready for Mid Ohio in 2018.
