'71 400 Issues/Restoration
Discussion in 'Vintage Restoration Projects' started by mike328, Jun 6, 2010.
  1. mike328 Husqvarna
    colorado
    I decided to just consolidate so I am just gonna refer to my posts as '71 400 issues..don't wanna call them problems.
    Anyway, had the frame already & received the engine this week.
    Used sandpaper & ruffed up the mounting points on the frame & engine, as well as the mounting bracket on the frame for the ignition coil to remove some of the new paint..Got the engine in, mounted the ignition coil & no spark.
    Where should I begin to troubleshoot this?
    thanks in advance.
    Mike
  2. oldhuskychuck Husqvarna
    Denver Co
    you have to do more then rough up the points,,
    i ground the pain off exposing the metal, same thing with the area were the coil mounts.
    all your grounds have to be on bare metal.
  3. mike328 Husqvarna
    colorado
    Yep Yep.."Rev"... sanded down to bare metal on the engine top front mount & frame,
    engine rear bottom & Frame, & frame for ignition coil..
    Ohm'd coil its; 4.88...with plug cap on HT wire..
    Right now checking for spark..
    also this is a newly rebuilt engine & I'm also using 2 stroke oil in the bore to lube as I 'crank'...don't want any 'scoring'..
  4. mike328 Husqvarna
    colorado
    well, long story short..the paint on the jug is the problem, as I held the plug against the jug, It wasn't grounding..
    geesh!..
  5. crankpin Husqvarna
    England
  6. mike328 Husqvarna
    colorado
    LMAo..yea I feel like a real horse's hind 1/4...
    I make sure the coil mount has its paint removed..use star washers to 'bite' the frame for the coil etc...
    I found out because I had a small chip in the paint from the place I put the spark plug..I noticed it sparked after I had chipped the paint...
    Now I need touch up...LOL
  7. mike328 Husqvarna
    colorado
    Looking source(s) for the 4 engine mounting bolts, and the one bolt for the kick starter.
    for a 71' 400 (MI Frame)
    New would be preferred.
  8. oldhuskychuck Husqvarna
    Denver Co
    yea know, i have boxes of Husky bolts and parts...if you PM me, ill give you my number, you can come over and get what you need....
  9. mike328 Husqvarna
    colorado
    Anyone know Bolt sizes (length etc) for rear sproket AND were the bolts nyloc?
    Re: 1971 Husky
  10. oldhuskychuck Husqvarna
    Denver Co
    Mike? you know i have them...
  11. mike328 Husqvarna
    colorado
    LOL......ok..
    I hate to be a PIA.....
    I am getting use to this site I may need to ask mods to move this to 'vintage restorations'
  12. Coffee CH Owner
    Re-naming thread and moving into restorations as requested...
  13. mike328 Husqvarna
    colorado
    some progress
    finally got around to getting some photos on here to show the progress.
    Couldn't resist, had to lean the wheels up against her to get more 'visual' of wheels etc...
  14. HuskyT Moderator
    Corona, California
    Mike!
    Great pics. Glad to see the 400 Restoration in here. Looks like a top notch job so far.
    Who did your motor rebuild? or was it you?
    T
  15. mike328 Husqvarna
    colorado
    Thank you "T"
    John LeFevre did the engine..
    well for that matter the bike while I assemble..
    (I had Woody's wheel works true up the rims)
    I will post more photos, I'm that person who afterward says 'wish I would have taken photos of that (insert experience; bigfoot, UFO, vacation,.. Husky 400 restoration)...
    LOL...
  16. mike328 Husqvarna
    colorado
    more progress
    ok....I'm not claiming to be a national geographic photographer..(lol I suck)
    But here's a few of the small parts that have been restored and not on the bike yet.. The exhaust, (tried to fit it all) & handlebars (magura grips etc)...the front fender/flap & bracket (red nyloc nuts & correct bolts) ... seat re-upholestered.
    decided to take the exhaust outside & try to get better angle..I failed
    Tim Court likes this.
  17. mike328 Husqvarna
    colorado
    side note
    Just a side note..I am kinda 'refreshing' a Bultaco Alpina..(not restoring)
    I had the exhaust ceramic coated..had it on the bike & was running, then decided to do seals in it!
    but the coating does help in the radiant heat.
    the finish is satin black...
    this is just a FYI..
  18. HuskyT Moderator
    Corona, California
    Pics are worth 1000 words, especially detail pics... yours don't suck. They are quite good in fact. Keep up the great work!
    I like how the bars shine!!!
    My buddy in Canada does some freelance Nat Geo work... every now and then he has a pic that sucks... then again they don't buy it !:D:D:D
    T
  19. HuskyT Moderator
    Corona, California
    You are our first admitted active Woody's vintage Customer in here... tell us more about your experience there?
    T
  20. Leftcoast leftkicker Husqvarna
    encinitas ca
    T- actually no, he built my race wheels on the '82 430CR. Top notch, expensive, and wouldn't hesitate to recommend.
