Has anyone fitted a Booster Plug to their 701? I'm thinking of getting one for mine. I have one on the Terra and it does work beautifully on that. Plus it's a much cheaper option that a Power Commander...
I had a booster plug on my GS and ended up removing it and had a power commander installed and dyno tuned. This meant removal of the exhaust sensor and made the fuelling closed loop (I. E. Made the fueling run off a 'map' than adjusting from exhaust sensor to reduce emissions) Not sure about the 700 but if you've got a smart fuel system with eexhaust oxygen sensor it can try to correct the fuel settings the booster plug sends, effectively making the booster plug redundant after a few rides
Best thing to do on the 690/700 is to get rid of that terrible pipe stock pipe if you haven't already got a Wings or Akro installed. The stock fuelling is still a little lean on the stock switch.
Agree with getting rid of the stock pipe. Cats are the problem. If it runs to lean, then add a BP or PC5. That's what I learned from the terra
