630 ECU number
Discussion in '610/630' started by Randell, Nov 23, 2020.
  1. Randell Husqvarna
    Honolulu, Hawaii
    2011 SMS630
    KTM RC8R Ducati 1199 Panigale CB750
    Hello everyone,
    Can you post what part number is on your ECU? I think my 2011 SMS 630 computer is bad and I'm trying to find a replacement. Websites show many different part numbers. Mine, however, seems to be the wrong part number. It is 8000B0564, but I'm coming up with an ECU from a 2008 450/510 with that number. Can anyone confirm this?
    Thanks in advance!
  2. Randell Husqvarna
    Honolulu, Hawaii
    2011 SMS630
    Can anybody help me out with ECU numbers? Also, I have been trying to find someone locally and on facebook groups to test out my ECU, but have not had any luck. Anybody willing to test my ECU if I pay for shipping?
  3. willie Husqvarna
    NS Canada
    TE 630
  4. kirbybikes Husqvarna
    Always thought the SM was different from the TE so here is mine to compare.
  5. willie Husqvarna
    NS Canada
    TE 630
    As far as I know, the only engine and control difference is a slightly lower 6th gear in SM. SWM use the SM gear ratios in their Superduals.
  6. Rotax_655 Husqvarna
    If I can around the world
    ex TE 630
    Aprilia Pegaso 650 GA
    If you put two photos of your ECU, one in front and one behind, it is possible to trace the model you installed based on the spare part code
  7. Randell Husqvarna
    Honolulu, Hawaii
    2011 SMS630
    Thank you for the pictures and responses. Here is a picture of the front and back of my ecu. There is nothing on the back 20201204_092617.jpg 16071114686773791351225222163536.jpg
  8. Rotax_655 Husqvarna
    ex TE 630
    someone has removed the references to understand what type of control unit you have. the main difference is that the mappings are different between SM and TE. furthermore, in the factory there are other basic differences set for the control of polluting emissions. do you have an Ibeat available to enter the control unit and check the parameters?
  9. Randell Husqvarna
    Honolulu, Hawaii
    2011 SMS630
    Yes, I have an iBeat setup. What do I need to look for?
  10. Rotax_655 Husqvarna
    ex TE 630
    what serial number does your ECU have? i mean the ID number you can select with ibeat. here's mine
  11. Randell Husqvarna
    Honolulu, Hawaii
    2011 SMS630
  12. Rotax_655 Husqvarna
    ex TE 630
    someone has changed the factory data by deleting them and you probably have a "racing" ECU that can give problems. does the bike work well? we are waiting for someone to put in his SM630 data
  13. Rotax_655 Husqvarna
    ex TE 630
  14. Randell Husqvarna
    Honolulu, Hawaii
    2011 SMS630
    Why would someone delete that data and what is a "racing" ecu? The bike doesnt currently run, but your info may have turned my direction as to why. I thought the eeprom chip was bad because it's not reading and I have a code, 4080, for eeprom read error, but if someone deleted those, then that may not be my problem. Long story short, I got the bike not running because the throttle body boot blew off from a huge backfire. Ever since I got the bike, the neutral light was blinking, but I didn't mind because it ran fine with the TB boot back on. I rode it for a couple of months. The only issue I had was if I shut the bike off after being up to temperature, say to get fuel, it wouldn't idle without throttle until riding again.
    One day after stopping, I could not get it started. I couldn't hear the fuel pump and it had power at the connector, so I put a new pump and filter in. Pump is running, it starts fine, then seems like it runs out of fuel or something after 10-15 seconds. I can keep it running indefinitely by constantly blipping the throttle, but if I hold the throttle, it still dies. I got iBeat and found the eeprom read error, but if it's what you're saying, that was probably there the whole time. It's doing the exact thing my RC8R did when I didn't have the map sensor hooked up. The MAQS seems fine, and it reads pressure and temp on ibeat. I also ran the recalibration on iBeat. How can I tell if the sensor is bad? How do I check the fuel pressure when running? Any help is appreciated!
  15. Randell Husqvarna
    Honolulu, Hawaii
    2011 SMS630
    My VIN is ZKHLDEKP1BV000178, so that should be correct for a USA model SMS630
  16. willie Husqvarna
    NS Canada
    TE 630
    It appears the eeprom is corrupted. Is there any way to update and reinitialize it?
  17. Rotax_655 Husqvarna
    ex TE 630
    So if you want to reconfigure the bike as in the factory you should get a suitable ECU ...... I seem to remember that Dynobob had a ECU suitable for a SM630 "USA" model.
  18. Randell Husqvarna
    Honolulu, Hawaii
    2011 SMS630
    Good question. Anybody know if this is possible?
  19. Randell Husqvarna
    Honolulu, Hawaii
    2011 SMS630
    Thanks! I'll message him
  20. HuskyBrutha Husqvarna
    SM630
    690 R, 500 EXC, XR250
    Got both the SM and TE, both have 8000B5064 as ECU numbers
