Hey all, looking for help diagnosing this weird turn signal pattern as seen in this video. Anybody run into this before? Gotta love electrical stuff View: https://youtu.be/BukJAmHiarg Facts: - LED lights all around. - Everything was working fine before. - Just rebuilt the engine as a transmission bushing let go. - After reassembly, the signals themselves were working fine (hyper flashing due to the LED's, but it was doing that before, and I was fine with it, it was not this weird pattern) But i don't see why this would change anything as it was just unplugging and re-plugging connectors. - Turn signal indicator on dash never worked after reassembly. - Over about 2-3 months of riding, they would intermittently not work at all. With some wiggling of the wires behind the headlight, they would either flash weird or stay on solid at around half brightness. Any ideas would be much appreciated, I'm definitely not familiar with the ins and outs of the electrical system on these. Thanks!!
Update just to close this off. Replaced the turn signal relay with an LED one to eliminate hyperflashing off amazon. Works fine now.
Hey man do you have the link to the relay that you bought and do you remember if the old relay you replaced was a T 111. I’m running into the same issue except mine are hyperflashing way faster.
https://www.amazon.ca/gp/product/B01CJ5SVXQ/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 This is off the Canadian site, and its nothing special, any relay designed for the same thing should work. It wasn't plug and play, but nothing off amazon ever is. Wired on my own automotive waterproof connector, signals work fine, however the indicator light on the dash does not, failed around the same time, not sure if its this relay or something else.
