I have a 2000 left hand kick TE610 without the electric start. It has the gauze filter on the right hand side of the engine. Under the engine on the sump there are three bolts, the one on the right is a sump bolt with a magnet on it. My question is what doe the other two bolts do? Is there a second sump bolt that I also should remove to drain the oil? How often do you change your oil? The bike is not used off road and not driven hard so I was thinking every 1000 miles? Thanks Sean
