250-500cc 250 / 300 / 360+ Jetting Database
Discussion in '2 Stroke' started by MattR, Mar 23, 2010.
Thread Status:
Not open for further replies.
  1. MattR 2T Forum Clerk
    Temperance, MI
    WB165, SM610
    Yamaha FZ1
    This database is for jetting setups on the CR,WR 250 / 300 / 360+ bikes.
    The goal is to list your carburetor settings and provide a brief conclusion of the results.
    Please do not post jetting questions in this thread.
    These questions should be posted in Jetting Chat.
    You should copy and paste this list below into your reply. This will help keep a common format.
    Year & Bike Model =
    Carb =
    Pipe & Silencer =
    Other engine mods =
    Gearing =
    Premix ratio & fuel type =
    Temperature range (deg F) =
    Elevation (feet) =
    Main jet =
    Pilot jet =
    Needle =
    Clip position =
    Air screw setting =
    Slide =
    Conclusions/Results =
  2. PC. Husqvarna
    Beaverton, OR
    CR165 & CR144
    KTM500
    Year & Bike Model = 2009 WR300
    Carb = Keihin PWK 38
    Gas/Mix = Chevron Premium/Klotz R50 @ 40:1
    Pipe & Silencer = 'New' Pro Circuit Platinum 2/Type 296 silencer
    Temperature range (deg F) = 55-65f
    Elevation (feet) = 3700-4200
    Main jet = 178
    Pilot jet = 45
    Needle = stock needle from 2000 Honda CR250. Dont know p/n :excuseme:
    Clip position = #2
    Air screw setting = 1.5 - 2
    Slide = 7
    Conclusions/Results = Only rode it once in the high dez and all circuits were rich. The needle probably being the worst culprit. Bike ran hard, did not spooge on the silencer and revved out decently, but it would have to clear out after any extended low speed riding and throttle response was suffering. Need to test at my usual ride spot at lower elevation, but that setup was quite rich at 4000' with mild temp and low humidity.
  3. BikeSDP Husqvarna
    Longmont, Colorado
    None @ moment
    990 Adv, Multistrada 1200, 500 EXC
    Year & Bike Model = '09 WR300
    Carb = Keihin PWK 38 AS
    Pipe & Silencer = Stock 300 pipe, FMF Turbine Core II silencer with spark arrestor
    Other engine mods = none
    Premix ratio & fuel type = 40:1 91 or 93 octane
    Temperature range (deg F) = 55-75F
    Elevation (feet) = 5100 - 9000+
    Main jet = 162
    Pilot jet = 45
    Needle = JD Red
    Clip position = 2 (from top)
    Air screw setting =1.75 out
    Slide = 7
    Plug = BR8EIX (Iridium)
    Conclusions/Results = This is my first 2-stroke, so I'm just kind of learning how it's supposed to sound. I've been running the PWK for nearly 2 seasons now and it runs great. Usually starts on 2nd or 3rd kick when cold, idles well and transitions well from 1/4 to 1/2 to WFO. It's been running so well that I haven't even had to think about tinkering with the jetting.
  4. Johnnymannen Husqvarna
    Sweden
  5. PC. Husqvarna
    Beaverton, OR
    CR165 & CR144
    KTM500
    Temperature range (deg F) = 50-55f
    Elevation (feet) = 1500-200'
    Main jet = 175
    Pilot jet = 45
    Needle = N3EJ
    Clip position = #2
    Slide = 7
    Conclusions/Results = BINGO! That leaner needle and the smaller main jet were spot on for my local ride spot. Pilot felt a little fat, but could probably have been tuned out with the air screw. I was having too much fun to worry about it though
  6. Motosportz CH Sponsor
    PC your welcome to try my JD red needle next time we hook up for a ride. Just to see if that gains you anything. I liked the JD needle over the Kehin ones I had paying around. :thumbsup:
  7. Skyldig Husqvarna
    Sweden
    1999 WR360
    CRF100, CR250, KX60, ZXR
    Year & Bike Model = 1999 WR360
    Carb = Keihin PWK 38 AirStriker
    Pipe & Silencer = FMF Fatty pipe / standard eu model
    Other engine mods = "the airboot intake mod"
    Premix ratio & fuel type = 1:50 (2%) currently MAXIMA Castor 927 (otherwise Castrol Power1 TTS Fully synthetic). 98 octane
    Temperature range (deg F) = 10C (50F)
    Elevation (feet) = Sea level
    Main jet =172
    Pilot jet =42
    Needle = n/a
    Clip position = 2nd
    Air screw setting = 1 3/4
    Slide = n/a
    Conclusions/Results = Switched to PWK from TM38 today. Amazing results. I really couldn't get the Mikuni to run perfectly. The new carb fired up on the first kick. After adjusting the throttle height and air mixture/speed the PWK idled perfectly steady. Respons was also good, felt almost like a smaller cc bike :) The best of it all was that it ran clean all the way to the top revs, even if I'd been on low revs for a while. The main 172 and pilot 42 was just a lucky shot. I googled some threads about jetting the pwk on the 360 and figured it should be something like this. PWK FTW :D
    Edit: added fuel type.
    Also, changing carbs was a job that didn't take long at all. Some people say you need to release and lift up the alu sub frame but that is not necessary (as long as your airbox rubber connection still is soft). The PWK body is a bit "longer" compared to the TM but still fully possible without causing any damage.
  8. kzoo Husqvarna
    Michigan
    WR 295
    Year & Bike Model = 2008 WR250
    Carb = Keihin PWK 36mm Quad Vent (yes I said 36mm)
    Pipe & Silencer = Stock pipe with FMF turbine core 2 spark arrestor
    Other Engine Mods = None
    Premix & Fuel = 50:1 Amsoil Interceptor w/ 91 or 93 octane.
    Temperature range (deg F) = 85-95 degF
    Elevation (feet) = ~1000 feet
    Main jet = 175
    Pilot jet = 48
    Needle = DDK
    Clip position = #3
    Air screw setting = 1.75 turns out
    Slide = 6.0
  9. hrc630 Husqvarna
    CANADA
    Hi the Sweden man !
    For me, this little piece of metal is a joy !
    I have ordered it directly from Scaryfast and have receive it in 3 business days.
    My current jetting on my WR300 2010 is:
    Keihin PWK 38mm AS
    Main Jet : 178
    Pilot Jet : 42
    Needle : CEL, 2nd clip from the top
    Slide : #7
    Air screw: 1 1/2
    Fuel/oil mix : 40/1 with Mothul 800
    Yesturday i have ride 3-4 hours and the jetting is really spot on. No miss, no ping, very responsive down low and so strong from middle to top. This motor is now more user frendly since the bottom end is more strong (that reduce the big hit when it goes on the pipe).
    This week i will put 1 or 2 more teeth on the front sprocket... im sure the motor will take it no trouble now.
  10. wildturkey Husqvarna
    NZ
    Year & Bike Model = WR360 2000
    Carb = PWK 38mm
    Other engine mods = Auto-decompression Head
    Premix ratio & fuel type = 40:1, Motul 800. Premium unleaded (93 Octane, I think)
    Temperature range (deg F) = 28c (~81f)
    Elevation (feet) = Sea level for testing, but I normally ride between 1000 - 4000feet.
    Main jet = 170
    Pilot jet = 40
    Needle = R1369LS (Somewhere around a CEK needle, I think)
    Clip position = 2nd
    Air screw setting = 1.5 turns
    Slide = 6.0
    Conclusions/Results = Earlier today, I had the clip in the 3rd position and was running a 35 pilot jet. It idled, but it was still fluffy from 1/8 to 1/4 throttle. So I moved up to a 40 pilot (just because I figured a 35 is too lean) and the clip to the 2nd spot and it's run as clean as I've ever had it running.
    I swapped to the PWK a couple of days ago, and this is the jetting I've settled on. I maybe running slightly too lean. I may have just got use to seeing my bike smoking a lot - now there is very minimal/if any smoke when the engine is warm.
    Just went for a short ride on a new plug. It came out blackish - so still running rich, but nowhere like before. I'll ride it as is for a proper ride and see how it goes for a whole day.
  11. 2stroked Husqvarna
    B.C. Canada
    JD Jet Kit Installed
    Year & Bike Model =2007 WR250
    Carb = Stock
    Pipe & Silencer =FMF Gnarley/Turbine 2
    Other engine mods = -
    Premix ratio & fuel type = 50:1/92
    Temperature range (deg F) = 0 to 30 c or 32 to 86
    Elevation (feet) =0 to 5000ft
    Main jet =390
    Pilot jet =32.5
    Needle = JD Blue
    Needle jet = JD jet S4(?)
    Clip position =middle pos.
    Air screw setting =1 1/2 to 1 3/4
    Slide =4.0
    Conclusions/Results =Very good throttle response, very good low/mid/high end power and over rev
  12. Rob578 Husqvarna
    Atlanta GA was CA
    Beta 300RR Beta 500RS TE 630
    Honda 919 sold FJR1300 sold
    2009 wr 300
    Here's my best settings
    Temp 95 degrees
    Humidity 80%
    Altitude 950'
    Fuel VP 110 50:1 Motul
    Kehin 38mm PWK
    165 MJ
    CEL middle clip
    35 PJ airscrew out around 1 1/2
    It freakin rips with no bogging or flat spots. plug chop is light tan.
    Will need to go to a 168 or 170 MJ when it cools off
  13. Bench Racer 117 Husqvarna
    Oregon
    2007 WR250
    Year & Bike Model = 2007 WR250
    Carb = Stock
    Pipe & Silencer =FMF Gnarly/ Turbine 2
    Other engine mods =
    Temperature range (deg F) = 40-90, set at approx. 75 degrees
    Elevation (feet) = 3200 is my elevation. But this jetting works everywhere for warmer days.
    Main jet =400
    Pilot jet =35/summer, 30/winter
    Needle = stock
    Clip position = 2nd from top
    Air screw setting = 2 turn out
    Slide = #3
    Conclusions/Results = Good low end through mid and top. Seems weird at my elevation to need stock jetting on the pilot and main, but that's what it wants.
    Note: Due to where I live, the dry climate is to blame. When it gets cold and wet, the 30 pilot is used. Otherwise it loads up and has a weak off idle rev.
  14. Wayneh Husqvarna
    Cape Town
    Carb = stock Mikuni
    Pipe & Silencer = Stock silence & Gnarly Gold pipe
    Other engine mods = nope
    Temperature range (deg F) = 10 - 30'C
    Elevation (feet) = 0 - 500
    Main jet = 380
    Pilot jet = 28
    Needle = stock
    Clip position = 2nd ring from top
    Slide = ?
    Conclusions/Results = Good crisp bottom end revs - suits my slower (low rev) more technical trail riding. :thumbsup: Tried the standard settings (400 main, 35 pilot, 3rd ring on needle) killed the spark plug every 2 hrs of riding. :banghead:
  15. Johnnymannen Husqvarna
    Sweden
    I did some rejetting on my 300 today as it´s about 8-15 degrees Celsius here now at sealevel. I have Supermoto setting now with slicks, 15/38 gearing:
    Keihin PWK 38 AS
    Pilotjet 42, 2 turns out
    JD Red needle in 2nd slot from top
    180 mainjet
    JD needle is smoother from the bottom than EEL, which is good on the streets when it´s cold and the slicks ain´t so sticky:eek:, otherwise EEL in 2nd slot from top is strong from the bottom for gnarly terrain.
    Pulls good all the way and revs to the moon!
    Johnny:sweden:
  16. ohmygewd Husqvarna
    Melbourne, Australia
    Aprilia RSV1000
    Year & Bike Model = 1996 WR360
    Carb = KEIHIN PWK 38MM AS
    Pipe & Silencer = FMF Gnarly and FMF Powercore
    Other engine mods = N/A
    Premix ratio & fuel type = 40:1 sometime 33:1
    Temperature range (deg C) = 15 to 25C up to 36C
    Elevation (metres) = 0-800m
    Main jet =170 to 175 (summer)
    Pilot jet =38 to 40 (summer and higher elevation)
    Needle = JD Blue
    Clip position = 2nd
    Slide = #7
    After much fooling around and my style of riding that the 0-1/2, the combination of a 38 Pilot, 2 turns out and 2nd Clip and Slide 7 is about spot on for my base line setting. I have to be careful with the Clip and 170 main if l'm riding wide open trails or summer
    Most of the fouling issues now are due to poor warming technique (in winter).
  17. MR54L Husqvarna
    QLD AUSTRALIA
    WR250
    Hi, All
    I will give the spec's my bike runs in Sydney Australia
    Year & Bike Model = 2008 WR 250
    Carb = TMX38
    Pipe & Silencer = DEP PIPE & FMF TURBINE CORE 2
    Other engine mods = 0
    Premix ratio & fuel type = 98OCT 50:1 MOTUL 800
    Temperature range (deg C) = 18-20
    Elevation (meters) = 250
    Main jet = JD 390
    Pilot jet = JD 30
    Needle = JD RED
    Clip position = 3RD
    Air screw setting = 2 1/4
    Slide = 3
    Air filter: Twin Air
    Conclusions/Results = my bike was real bad to ride. The float level was 2mm too high. This was a constant cause of fouling plugs. I would foul 2-3 plugs every ride, this would happen riding in the lower rev range on tight tracks. On down hill descent, I would get to the bottom twisting the throttle only to foul another plug. The high float level was the cause of flooding, burning off the fuel, but not all the oil. I also had the same problems riding on flat ground in the lower rev range. Heavy braking would also fuel the engine up and foul another plug. On cold start up my bike would moan and cough. I was at the point of no return, this constant headache had to go.
    The above specs are a recipe that has now produced a nice clean crisp bike. On cold start up, I do not require the choke. The engine spins up very quick with no moan, and no longer fouls plugs. The bike now rides like a dream, pulls hard off the bottom right through to the top end
    With that jetting and pipe combo, my bike produced on the dyno
    42rwhp, 26ft/lb torque @ 8500rpm.
    A big thank you to Steve Cutting
    @ Motorcycle Weaponry 7/8 Wilmette Pl
    Mona Vale
    NSW
    Australia
    Ph: 029979 4744
    Fax: 029979 4745
    Motorcycle Weaponry is also on the Net[/U][/U]
    scottcr250 likes this.
  18. MR54L Husqvarna
    QLD AUSTRALIA
    WR250
    Hi Johnny,
    Yes I did try the 35 & 32.5 pilot, 380, 390 & 400 main
    35 & 32.5 pilots were too rich off the bottom
    380 main was a fraction too lean on WOT
    400 main was a fraction too rich on WOT
    The 08 WR250 Carb is a slightly different set up to to 09-10 although they do look the same
    I have a number 3 slide making the settings rich enough for the 390 main
    The higher the number on the slide eg: 4.0, 4.5, 5.0 you will find they take a
    higher number on the main jet eg: 400, 410, 420, 430, 440
    The factory float level settings were my biggest problem
    I was seeking a reliable bike that I can ride without any problems,
    I did not anticipate that it would become a two wheel weapon
    Regards Col
  19. fire1998 Husqvarna
    Cheyenne, WY
    Hey guys,
    Put a PWK on my 09 300. It currently has the red JD needle on the middle clip, 170 main, 45 pilot and the air screw at 1 1/2 turns. Bike runs great down low and thru the mid. Up top it goes flat and runs poorly. Should I go to a 168 main or? Bike has a Gnarly pipe and Turbine muffler. I will be riding around the 5000' to 6000' this winter.
    Thanks
    lankydoug likes this.
  20. pvduke Husqvarna
    ... on the gas...
    tripple-hondo hoosk...
Thread Status:
