TE/TC 2017 TE/TX Plug choice BR7ES vs. BR8EG?
Discussion in '2st' started by 95jersey, May 2, 2017.
  1. 95jersey Husqvarna
    TXC310R
    2014 Gas Gas 300 XC
    I see the manual calls for BR7ES vs. the industry standard BR8EG. I have a bunch of BR8EG's from other bikes, any reason I can't use it?
  2. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    It's just a colder plug so couldn't see why not. Potentially could foul easier
  3. ohmygewd Husqvarna
    Melbourne, Australia
    Aprilia RSV1000
    One heat range isn't gunna make a drastic effect!!
  4. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
    no its not going to make a huge difference...... but why goof off from the OEM spec heat range????? BR7ES came on the bike BR7EIX is what is now on the bike (Iridium BR7 plug)
  5. 95jersey Husqvarna
    TXC310R
    2014 Gas Gas 300 XC
    I ran the BR8EG in a race Sunday and it ripped. Very crisp.
  6. KXcam22 Husqvarna
    Kamloops, BC, Canada
    2011 SM630, 2017 300XC
    08FZR6;07CRF450;98CBR900RR;02KTM200
    My plug of choice is always the BPR8EIX. The protruded nose runs super clean and lasts. Cam.
  7. ajaxauto Husqvarna
    I run the cheap 2 dollar regular br8eg in my 2016 TE 300 now for almost 2 years never a problem also use 110 leaded race gas mixed 50 to 1 with lugas oil
  8. KXcam22 Husqvarna
    Ajax, You should try the EIX. You can actually tell the difference in how much better the bike runs. Its surprising. Heck I put one in my lawnmower because of that. Cam.
  9. robertaccio Husqvarna
    San Diego, Ca
  10. Cosmokenney Husqvarna
    North Auburn, CA
    '17 TX300
    Yamaha FZ-09
    I don't know if it matters but what premix ratio do you guys running Iridium plug use? I've been running 60:1 per the manual for at least 30 of the 49.7 hours on the bike. Seems goot at that ratio.
    Plus, the '17s switched from a BR8 that the '16s and earlier bikes had, to BR7. There must have been a reason for it?? It is a new motor after all.
  11. 87husky500xc Husqvarna
    Dayton NV
    2020 tx300i and a few vintage bikes
    77 honda xr-75..
    Stock on my 15 is br7es....per the manual
  12. robertaccio Husqvarna
    San Diego, Ca
    BR7EIX is in my 2017 TX300----use the OEM engineered heat range for your model, with the OEM recommended mixture ratio with the OEM or exceeding fuel requirement. they didnt just decide on whim what to use they spent doses of hours in r&d instrumentation and testing getting the most data to come up with the best engineering solution to put the bikes to market. my 2 cents. that's worth way more.
    gaz likes this.
  13. Cosmokenney Husqvarna
    North Auburn, CA
    '17 TX300
    Yamaha FZ-09
    Oh, my bad, I thought i read either on this forum, or in a review, that they changed the plug with the new motor.
