TE/TC 2017 Tc125 Bottom End And Repair Manual
Discussion in '2st' started by rob kelly, Jun 12, 2018.
  1. rob kelly Husqvarna
    1972 wr250
    Hi,
    I went to change the piston and bearing in my '17 tc125 today and after a bit of inspection i think there is excessive play in the big end bearing. I can't find any tolerance specs online nor can i find a repair/ workshop manual. Does anyone know where i could get one from?
    The rod rocks side to side 1.4mm (measured at the small end), the gap between the side of the rod and crank is 0.64 mm and there doesn't appear to be any vertical or twisting movement of the rod.
    This all seems a bit sloppy to me.
  2. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    Measure between the thrust washer and the rod. Seems like most small bore engines should have about 14 thousandths. 25 does seem a bit much. But I am not familiar with these newer bikes. The top has to be able to allow the piston "float' slightly as it moves through its stroke in the bore.
  3. rob kelly Husqvarna
    1972 wr250
    thanks for your reply. Yes that was where i measured- between the thrust washer and rod. 25 thou" / 0.64mm is the gap.
  4. Up-tite Husqvarna
    Not a big deal most all cranks have at least 19+ thou,
    Most important dimension is total width of crank shaft to the main bearings.
    This amount of free play is critical.
    Any up and down movement on the rod is no good.
    Top rod wiggle is ok even new they have it.
    Later George
    rockdancer likes this.
  5. John Bunker Husqvarna
    Mid Michigan
    TE150 2017
    XR250 Honda 1985
    As per the shop manual, axial play of lower connecting rod bearing, .017 to .0295
  6. geky83 Husqvarna
    Italy
    HI guys, whare can I find a repair manual for the 2017 TC 125?
    thanks
