2015 Te300 Starter Issues Out Of The Blue
Discussion in '2st' started by Jeepcj66, Sep 19, 2018.
  1. Jeepcj66 Husqvarna
    2015 TE300
    2002 KTM 540exc, 2005 KTM 250exc
    So I washed the bike as normal after sat-sun ride and cleaned air filter. Fired bike up today went around the block no issue but when I stopped and pushed the Ebutton a second time to restart nothing??? battery reads 12.9v, no click from relay when you hit the button nothing.... You can short the relay with a screw driver and get the starter to go but nothing via the button? thoughts? I"m thinking relay, all the fuses are good might be a little corrosion on the fuse connector blades but other wise nothing noticeable, I cleaned them up and still nothing.
  2. Jeepcj66 Husqvarna
    2015 TE300
    Checked my E button and it was clean, pulled a solenoid off my old 520 and put it in and bingo it works. I guess the new solenoids are not as robust as the old ones. My 520 is 18yrs old and still going the 300 is 3yrs old and dead wth?
  3. 87husky500xc Husqvarna
    Dayton NV
    2020 tx300i and a few vintage bikes
    77 honda xr-75..
    Strange, my 15 starter works great still @ over 180 hours and still on the factory battery (which most guys swap out). I imagine it’s one of least expensive components of the starter at least.
  4. Billd Husqvarna
    Pensacola FL
    1975 CR 360 GP, 2015 TE 250
    wire behind the light in the big white connector was the issue on my 2015 te250. corroded
  5. Jeepcj66 Husqvarna
    2015 TE300
    Ended up being my starter relay. Pulled one off a ktm520 and swapped it, worked perfectly. Go figure a 18yr old part is still working while a 3yr old part is dead already??
    PDL likes this.
