TE/TC 2014 TE300 E Starter
Discussion in '2st' started by Pete, Jul 11, 2017.
  1. Pete Husqvarna
    Victoria, Australia
    2014 TE300
    Mine has a brand new battery, brand new bendix - this was from a newer model so I added a new crown gear from Slavens and bushes, shimmed. Pulled the starter apart and cleaned it and put all back together.
    Even with new bendix, it doesnt throw the gear, it just spins.
    What do i look at next?
  2. Pete Husqvarna
    Victoria, Australia
    2014 TE300
    anyone?
  3. hhdwtmtw He who dies with the most toys wins...
    Melbourne, Australia
    '14 TE300, '11 TE449, '10 TE250
    Royal Enfield Continental GT 650
    Did you mark the starter magnet assembly before you disassembled it?
    It has not got any locating lugs and if you rotate it the motor will run poorly or backwards. Running backwards will cause the Bendix to never spin out.
    Some housings have a line marking, some a faint paint mark. I'll find the article I found on the alignment and post it.
  4. Pete Husqvarna
    Victoria, Australia
    2014 TE300
    No i didnt mark it - but i did fully disassemble it, it was open circuit, fully jammed with mud, i cleaned and re assembled and it ran - but i never thought to check if it was spinning backwards - appreciate it if you have any details.
  5. hhdwtmtw He who dies with the most toys wins...
    OK. In the attached photo you can see a small mark on each end cap. The will have been a ink pen marking from the factory that aligns with these marks. If you look very closely you may be able to find the marking and align it properly.
  6. hhdwtmtw He who dies with the most toys wins...
    Worst case, ask a mate with the same bike to take the pinion end cap off a good motor (after marking the case) and use that as a benchmark to align yours. it will be trail and error (rotate the housing 180 degrees) to get it running in the right direction but you'll get it fixed.
    I couldn't find the article I was looking for. Probably due to the PhotoBucket hosting removing access issue.
    Good Luck.
  7. hhdwtmtw He who dies with the most toys wins...
    Trenchcoat85 likes this.
  8. Pete Husqvarna
    Victoria, Australia
    2014 TE300
    thanks mate - i'll pull it apart and tackle this tomorrow and let you know how i go.
    MUCH appreciated!
  9. Pete Husqvarna
    Victoria, Australia
    2014 TE300
    Well buggar me...i rotated the centre barrel 45deg and bang it starts. MANY THANKS!!!
    Originally this bike didnt estart when i bought it, i took a punt on battery issue. Got it home, super muddy in there, good battery, siezed bendix and open circuit starter. Cleaned the starter and replaced bendix - work once. New battery, starter adjusted (but on the last few starts on these brushes), new bendix and crown and it start sooooo easy :) Thanks again!!!:thumbsup:
    johnnyboy likes this.
  10. hhdwtmtw He who dies with the most toys wins...
    Well done. That's great to hear!
  11. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
