125-200cc 2011 WR300 Help Needed
Discussion in '2 Stroke' started by icebergstu, Aug 22, 2017.
  1. icebergstu Husqvarna
    South Australia
    WR300/TE610e
    WR360 CT110 XR100
    Hey,
    I was out riding in extremely wet high altitude last ride and the bike was running superbly as usual for a 600hr stock bottom end WR300...as expected.
    Then we turned up a steep single and carried on for a bit then the bike just died.
    It started straight up but died again quickly then died again. It continued with this behaviour and would run a bit but only at high RPM.
    I thought it must be a blocked pilot. Spun the carb around and ripped the bottom off to find a pristine bowl and clean jets. Hmmmm
    After reassembly it continued with this unruly behavior.
    I unplugged the heavily damaged light switch cluster and it rode perfectly from then on in.
    Now I have it home, I have removed and blanked off the light cluster and fitted a new generic kill switch.
    In my investigations I found this thing I had unplugged many moons ago and blanked off.
    What is it?
  2. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    Err it looks just like the kokusan ignition on my 10(albeit in a different position in the bike) but yours being an 11 will have Ducati ignition.
    Where's it run to/from? Possibly for indicators(flasher unit)?
