250-500cc 2010 Wr 300
Discussion in '2 Stroke' started by Chisler, Feb 3, 2020.
  1. Chisler Husqvarna
    British Columbia, Chilliwack River Valley
    2010 WR 300 Husqvarna
    Old man new on the block.. Proud owner of a Wr 300 .. I’m out in British Columbia ,Canada ... this is such an awesome site ... be following for a long time ... you guys/gals rock
    Thanks so much DirtDame to make this happen ... I’ll be sure to chime in on what I’ve done to my Wr 300
    She’s a killer woods machine for me .... most of the improvements to it have come from you all.
    Thanks so much !!!
    Chisler
    Durangedgoat and Dirtdame like this.
  2. Chisler Husqvarna
    Sorry for the double post
  3. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    Don't worry. I fixed that.
  4. Chisler Husqvarna
    So with all the reading up I’ve done here and hearing so much about the Large rear rotor kit mod some of you have done ...
    I went ahead and ordered the parts .... they are still available
    Shark fin ( Zip Ty ) - SF129
    Rear brake disc - 8B00H4977
    Disc fasteners - 800055878
    This conversion takes the rotor ( 220 mm ) and now becomes ( 240 mm )
    And the new fasteners make the disc a solid mount .. ( no more rattle )
    And the shark fin offers some good protection
    I just thought I’d put up the part numbers and let you all know ... it’s still out there .. : )
    Dirtdame likes this.
  5. Chisler Husqvarna
    I see Halls has a few sets of plastic on eBay up for the Wr these are oem ... included are the headlight bezel ... tank shrouds and the side panels ... good way to replace your worn/ busted up plastics with OEM .. and around 80 bucks for a complete set
  6. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    2011 TE449 2006 WR250
    Good call!
  7. Chisler Husqvarna
    Thanks to you ... a very nicely machined part that fits perfect to the bike
  8. Chisler Husqvarna
  9. Chisler Husqvarna
    So I dropped my seat off to get shaved down .... gonna try for the bottom looking one..... my stock one looks exactly the top one .... not much to work with ... should be ready Friday ... : )
  10. Chisler Husqvarna
    I also have lowered the Wr 300 25mm I’ll add the Zeta part numbers when I get a chance 90304CA6-F772-4E7B-A5E1-F5EE23B99636.png
  11. Chisler Husqvarna
    Clutch cable at the end of your adjustment ... try this little trick with some M8 washers
    : ) B2D4D4C5-8256-4DAE-ABA7-1AEAADAC9161.png A2E1550B-4926-4C6D-A437-9D0D7646141C.png B2D4D4C5-8256-4DAE-ABA7-1AEAADAC9161.png
    gaz likes this.
  12. Chisler Husqvarna
    Gets ya back in the game
    : ) 059E3470-86A0-444D-A00A-BE096D6638CF.png
  13. Chisler Husqvarna
    Don’t forget the cable lube while your at er
    FF6E5A0A-1A19-4086-928E-EA1BD798E456.png EFA76C85-5785-4C29-A6F9-8AB510DFA4DE.jpeg
  14. Chisler Husqvarna
    Oil lite bushing also works .... guess I got a lot time on my hands
    Goose719 and gaz like this.
  15. Dirtdame Administrator
    Rock Springs Wy
    17 Beta Xtrainer
    Chisler likes this.
  16. Chisler Husqvarna
    Yes .... time to lay the bike over ... pull the clutch cover .... I’m tryin to eliminate this clutch drag ... what brand of lubricant are you running .... maybe sitting over the winter the clutch plates are stuck together ... it is a motion pro clutch cable ..... but from what I hear these Huskys are notorious for clutch drag
  17. Dirtdame Administrator
    Rock Springs Wy
    17 Beta Xtrainer
    Using the Terminator cable by Motion Pro helps a lot, but nothing seems to eliminate the drag completely. I have been using Honda Proline transmission oil in both of my WRs. For some reason, the 125 doesn't have any problems at all with clutch drag, even with a stock cable. I suppose that this is because it is much daintier design than the one in the 300.
  18. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    not exactly the same
    but my 360 had some clutch drag and as they are in the same family it might count
    adjusted the clutch screw behind the cover, it helped
    went to pure synthetic, can't remember the brand at this moment, but it says clutch saver on the bottle
    after the 2nd oil change it seemed to be literally gone, hope that helps, maybe consider a different oil
    Chisler likes this.
  19. Chisler Husqvarna
    Thank you 2premo I’ll start checking that adjustment forsure ... and start doing some research on the lubricants you and Dirtdame have mentioned .
  20. Dirtdame Administrator
    Rock Springs Wy
    17 Beta Xtrainer
    Bel Ray says Gear Saver on it. Not sure if any brand has clutch saver written on it.
