2010 TE 250 Power Commander V mapping
Discussion in 'EFI/carb' started by Silas Ness, Jul 30, 2016.
  1. Silas Ness Husqvarna
    2010 TE 250
    2011 Suzuki DRZ 400
    My EFI was never re-mapped. I recently installed the PCV. Can someone point me in the right direction as to what my values should be on my fuel map to remove the hesitation in 1st gear that it came with from the factory? My map is all zeros currently. Some of the downloads on the Power Commander website don't seem to be working for me. It says they installed, but they aren't anywhere to be found on my hard drive. Thanks.
  2. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    2011 TE449 2006 WR250
    You can start by adding positive values in the cells at the bottom of the rpm range and the %throttle. On the website you can just click on download all maps and if using Windows it will automatically create a POWERCOMMANDER MAPS file in your documents. Then you open that and the maps should be there. I just checked and it seems there are only 2 maps for your bike, one of them being the all zero map.
    Also, if you're having trouble using the software, here is a decent video.
    View: https://www.youtube.com/watch?v=iA65eZxHa2w
