2008 TE450 fuel pump intermittent - dash N light flashing
Discussion in '4 Stroke' started by tntmo, Feb 17, 2021.
  1. tntmo Husqvarna
    2008 TE450
    A bunch of others.
    My TE450 has been acting odd starting this desert season (late last year). Sometimes the fuel pump wouldn't cycle on when I turned on the key. Turning it off and back on a time or two usually got it going without issues.
    Then after a few rides, the pump would stop during a ride. When this happened I noticed the N light flashing on the dash. Are there codes that this bike gives?
    Anyway, I figured my pump was failing so I installed a new universal one. The problem has not changed. I am likely going to order a new fuel pump relay as well just in case that is starting to give out.
    Anything else I should be looking at? This bike has never failed to get me home but now I am not feeling confident taking it out by myself anywhere.
  2. Special Ed65 Husqvarna
    2009 TE450
    2015 BMW F800GSA
    Make sure you battery is good, my bike was acting the same way (I think the N light was flashing too). It ended up being a bad battery. I replaced it and I have been trouble free for a year now. Mine is a 09 TE450
    tntmo likes this.
  3. tntmo Husqvarna
    2008 TE450
    A bunch of others.
    You been casing my house?? :p I just replaced the battery yesterday, also installed a new fuel pump relay (ordered trough SWM) and it has worked 10 of 10 times locally so far.
    I guess I will see how well it works, heading to the desert tomorrow if all goes as planned.
  4. tntmo Husqvarna
    2008 TE450
    A bunch of others.
    Just wanted to close the loop on this. I rode all day in the desert with the new battery, never once had an issue with the fuel pump. It seems that the battery was likely the culprit. I was getting close to giving up on this beast, but she's back in my good graces.
  5. Special Ed65 Husqvarna
    2009 TE450
    2015 BMW F800GSA
    Thanks for the follow up, Glad things worked out.:cheers:
    tntmo likes this.
