2008 TE250 Wheels on 2013 TE449. Will they fit?
Discussion in 'Super Moto' started by Evans449, Feb 20, 2017.
  1. Evans449 Husqvarna
    2013 TE 449
    CBR 954 RR
    New here, and read as much as I could before my eyeballs fell out. First post. Thank you all for your helpful info. I recently acquired a 2013 TE449 with 1300 miles, mostly stock. Looking for sumo wheels. I can get a set of warp9's from a 2008 TE250. Will they fit and bolt up to my 449? Factory pdf offers no axle/spacer size dimensions. Thank you
  2. rancher1 Husqvarna
    WA
    Yes they should, the only real change would be one of the front wheel bearing seals.
  3. Evans449 Husqvarna
    2013 TE 449
    CBR 954 RR
    Thanks for the input. Can you elaborate? Would I need the seals from the 08 TE250? Assuming i need both. Or have to have a custom set machined? Ideally I want the easiest swap back and forth between knobbies and motard. For now, I will be using the oem brake system and need the rotor to slot right in
  4. Evans449 Husqvarna
    2013 TE 449
    CBR 954 RR
    Anybody know what is needed to adapt these to a 2013 TE449?
  5. LandofMotards Moderator
    Colorado
    2014 TC250
    I would ask Jeff at Toxic Moro Racing
    Evans449 likes this.
  6. rancher1 Husqvarna
    WA
    One of the front wheel seals was changed, that is all. You would probably just to buy the seal that is different and switch it. I am running 2005 wheels on my TE 449 with out issue.
    shawbagga and Evans449 like this.
  7. Evans449 Husqvarna
    2013 TE 449
    CBR 954 RR
    I called Jeff at Toxic Moto, very friendly and helpful. Thanks for the suggestion. Need to measure the hub on the rear of both wheels, and may need a spacer. I will be doing that this weekend
    LandofMotards likes this.
  8. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    Yeah a $5 seal is all
