2008 te 450 fuel problems
Discussion in '4 Stroke' started by KDC, Sep 15, 2018.
  1. KDC Husqvarna
    2008 TE 450
    VESPA PX 150
    In downhills i run out of gas but i have about 3 lts gas on my tank. Is the fuel pump in the correct position on this model?
  2. Oldscool Husqvarna
    South Australia
    None
    RM125, SWM RS500R & Superdual
    Take the pump assy out and check the pump is securely located.
    Trenchcoat85 likes this.
  3. KDC Husqvarna
    2008 TE 450
    VESPA PX 150
    Its fine
  4. KDC Husqvarna
    2008 TE 450
    VESPA PX 150
    Is the pump in the lowest place of the tank? I think that in dawnhills all the gas goes to thr front of the tank and thats why it runs out of fuel. Is it possible?
  5. Oldscool Husqvarna
    South Australia
    None
    Have to be a bloody steep and long hill.
    If the pump is correctly positioned & secure and the hoses inside the tank are ok then I'm at a bit of a loss.
    How old is the fuel filter? Maybe try a new one.
    Test the pumps performance both pressure and flow.
    Does your bike have a tilt sensor that stops the engine in case of a fall?
    R_Little and Trenchcoat85 like this.
  6. KDC Husqvarna
    2008 TE 450
    VESPA PX 150
    I will check them and i tell you. How many km with one tank?
  7. Trenchcoat85 Husqvarna
    Northern NorCal
    '14 TE 310R
    I was thinking electrical. Does it idle okay? Possibly a problem with the filter or regulator that's exacerbated by the tilt.
    start the bike up, let idle a bit, and then pick up the rear wheel.
    it's a weird problem.
  8. Trenchcoat85 Husqvarna
    Northern NorCal
    '14 TE 310R
    also, characterize the problem for us... as soon as you head down, the motor stops or does it take a 5 min descent? how steep are we talking here? rough trails or smooth road? does it sputter? is restarting an issue? etc.
  9. KDC Husqvarna
    2008 TE 450
    VESPA PX 150
    In rough dawnhill trails if my tank is full with gas idont have any problem. In the same trail if im not full i have only 2-3 lt on the tank i run outt of gas. When the trail is over and find a streight road it starts up and runs fine!
  10. KDC Husqvarna
    2008 TE 450
    VESPA PX 150
    Thats why im asking if the fuel pump is in the lowest place of the tank
  11. Oldscool Husqvarna
    South Australia
    None
    The fuel pump is at the lowest part of the tank but at the rear of the tank.
  12. KDC Husqvarna
    2008 TE 450
    VESPA PX 150
    So that is happening is possible?
  13. KDC Husqvarna
    2008 TE 450
    VESPA PX 150
    Can the fuel pump drag gas from the front of the tank in dawnhills with some mods?
  14. Oldscool Husqvarna
    South Australia
    None
    Before you start modifying things I'd suggest something else is not quite right.
    I don't know about your particular model but my RS500 (which is effectively a 2010 TE510) has a rubber shroud or cover inside the tank around the fuel pump. I suspect it's to hold a supply of fuel at the pump when the fuel level is low and sloshing around the tank.....does your bike have this?
  15. Trenchcoat85 Husqvarna
    Northern NorCal
    '14 TE 310R
    ...not with 2-3 liters in the tank, unless you're going down long 45° hills.
    BTW, are you accelerating downhill or coasting? I've been assuming coasting but who knows?
    something is wrong. Could be plumbing (internal hose, filter, regulator), electrical (loose connection), or mechanical (your pump isn't strapped down etc). I suppose there could be a plastic bag floating around in there too.... naw. but your problem is probably NOT the inability to draw gas from the front of the tank when going downhill- I'm guessing.
    give us some GOOD pictures. Lots of 'em.
  16. Trenchcoat85 Husqvarna
    Northern NorCal
    '14 TE 310R
    Also you should get 100km per tank; 150km on a good day.
    A poster here had a rich running 450 and he got 25mpg (about 10km/lt)
  17. KDC Husqvarna
    2008 TE 450
    VESPA PX 150
    I dont have anything like cover or rubber shroud inside my tank only the fuel pump
  18. KDC Husqvarna
    2008 TE 450
    VESPA PX 150
  19. R_Little Husqvarna
    NJ
    The placement of the pump in the rear of the tank is not a bug, it's a feature and rather convenient when you run low on gas.
    While it will stall on downhills it will start back up and run on uphills. If you are running out of gas it is the uphills where you need engine power the most.
    Harder to push uphill!
    OTOH 3 ltrs of gas is too much for this to start happening. The stock tank only holds 6 ltrs of usable fuel and that is a half a tank.
    So some reason that pump is not picking up fuel properly.
  20. KDC Husqvarna
    2008 TE 450
    VESPA PX 150
    On streight path or uphills works fine. My problem is only on long dawnhills
