250-500cc 2006 wr250 sometimes gets stuffed up
Discussion in '2 Stroke' started by Wheelie, May 1, 2018.
  1. Wheelie Husqvarna
    2006 wr 250
    couple honda vtr's
    So I've got a weird thing with my bike, sometimes she gets stuffy & needs to clear her throat...
    2006 wr250 with a ton of hours (regularly 80+ a season, had it for 6? Years, many top ends & maintenance)
    She's not pretty & def not 'barely ridden' but I try to keep her in decent shape.
    Full fmf exhaust (gnarly pipe & turbinecore silencer)
    Lectron carb
    Piston about 40? hours ago, don't exactly remember
    New England tight singletrack rider. I ride aggressive, but tend to ride a gear high & lug it
    Most times I'm happy with the way it runs, crisp down low, pulls hard & clean, just like it should
    But every so often (usually in real aggressive riding, like a hare scramble) it seems like someone simultaneously stuffed a rag in the exhaust & punched a hole in the pipe, the bike will have a sudden, noticeable change in tone & not want to go anywhere. I know I run it low rpm sometimes but I don't think there's any reason it shouldn't light right up & go in 2nd or 3rd gear at any rpm. If I pull the clutch in while this happens and really ride it like a 125 (lots of gas & clutch work) it will get on the pipe and go, but it doesn't seem happy.
    Then, just as sudden as it starts running like that, it will go back to running the way I like.
    Top end of the powervalve assembly looks ok, it starts & idles well with the lectron, no bogging when it warms up, sometimes it surges off throttle but not bad I don't think.
    What's going on?
    I'm wondering if the centrifugal for the powervalve is old & tired? Maybe is hanging up & occasionally not opening, or is staying open? Electrical or fueling? I would think it would be more consistent if it was an electrical or carb problem? It seems load & intensity related. The change in noise is quite noticeable. The silencer isn't in the best shape, maybe it's coming apart internally? I just repacked it last week with no change in performance
  2. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    the cheapest and most suspect part of any dirt bike is the spark plug, do that first always
    the spark plug and actually the whole high voltage system has it's greatest strain during acceleration, I don't mean it actually works harder it's taxed harder
    but number 2 is look at the powervalve
  3. Wheelie Husqvarna
    2006 wr 250
    couple honda vtr's
    I'm ashamed to admit how old that sparkplug is... Good call, she's due for a fresh one anyways
    jimmyc likes this.
  4. gaz Husqvarna
    wr250
    The noise change is interesting, is the pipe sealing starting to fail, between the cylinder or muffler, shouldn’t cause a major power issue though. Got the same bike sadly sans lectron , haven’t experienced this with the maligned mikuni. Please let us know the outcome Wheelie.
  5. gaz Husqvarna
    wr250
    Perhaps the reeds are starting to fall apart?
