250-500cc 2006 Wr250 Motor With 02 Cr Electronics
Discussion in '2 Stroke' started by Thack, May 10, 2018.
  1. Thack Husqvarna
    Houston, Tx
    2002 CR250
    YZ426F, Ducati 748, Suzuki DR125
    I have a 2002 CR250 that is a basket case. Will an 06 WR250 motor accept my electronics and clutch components?
  2. rancher1 Husqvarna
    WA
    Yes, you will need all of the electronics. The clutch shouls also be good. The basket assembly has different part numbers but I believe it is due to construction or material. The rest of the clutch components are the same as well as the gear tooth count.
