125-200cc 2006 Wr125 Fork Springs and shortened shock
Discussion in '2 Stroke' started by Doug Schloegel, Sep 25, 2016.
  1. Doug Schloegel Husqvarna
    2006 Husqvarna WR125 & 2001 CR250
    1991 ktm 125 MX & 1993 KX 125
    I bought a 2006 WR125 this summer with only 30 hours on it. It's lowered. I already replaced the cut foam with new foam and cover from Guts. I pulled the fork apart and the springs are cut, and they installed a small aluminum spacer and 2" spring on the rod. It is also missing the plastic cup on top of the spring (under the fork cap) and the stock pre-load spacer. I'm not only having trouble getting these parts, but I can't seem to be able to find fork springs for this year in .44N/mm.
    Now the shock is shortened too. I don't know where to start on it. Maybe there's a spacer that I can remove? I was hoping to just find a good used shock on ebay, but none to be found.
  2. Doug Schloegel Husqvarna
    I do have the plastic cups on top of the springs.
  3. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
