2006 620 mid range stutter
Discussion in '610/630' started by Vold Hooker, Jun 27, 2016.
  1. Vold Hooker Husqvarna
    North Jutland, Denmark
    2016 FE-350
    2017 MT-09
    *610, not 620. Cannot edit title it seems*
    I've had the bike for the last 10k kilometers. It's got a full TI system on from Leo Vince and should be jetted appropriately.
    It's always had a bit of a stutter at just above mid RPM at constant speed. No problem when accelerating.
    It's best described as if the throttle is every so slightly chopped and then turned back on in rapid succession.
    I've more or less ridden around it but it makes balance point wheelies in 1st near impossible.
    Someone mentioned that a possible fix was an aftermarket sparkplug. Anyone else with similar problem?
  2. rancher1 Husqvarna
    WA
    Change the plug to a CR8EIX iridium plug, that should cure it.
    Vold Hooker likes this.
  3. rancher1 Husqvarna
    WA
    Don't forget to report back.
  4. Vold Hooker Husqvarna
    2016 FE-350
    2017 MT-09
    Will do. I am replacing the cam chain and doing the clutch cup replacement as well, so it might be a week or two before I get her running again.
  5. Vold Hooker Husqvarna
    2016 FE-350
    2017 MT-09
    The CR8EIX took care of the stuttering problem :) Now it's my lack of skill that prevents me from doing decent 1st gear wheelies.
    Thanks!
