1999 TE 610, OEM Specs
Discussion in 'Older Single cams' started by robertaccio, Mar 17, 2011.
  1. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
    I finally got the owners manual so here are the OEM basic specs
    (it has the TE410 &TC610 as well)
    This is for the TE610 only
    1.6L oil 10w40 Synthetic (middle of site glass)
    2.4 US Gal fuel tank
    Valve Clearance .1mm/.004in ex and in
    10:1 comp ratio
    577cc
    Dell'Orto PHM40 non pumper
    M175
    P62
    needle K32 P3
    atomizer AB264
    choke jet 60
    slide 50/3
    Air screw 1.5 turns out
    NGK C7E std (NGK C8E racing)
    final drive 14/48
    90/90-21 enduro comp
    140/80-18 enduro comp
  2. fran...k. Husqvarna
    eastern ct
    I have or once had a 1999 te 410 and noticed your post. I thought I had looked up accellerator pump parts differences for the different displacements. Upon studying the sheets it appears the te 610 does qualify as a non pumper but the other 610 versions do have the pump parts in them. Mine also had a 2.5 inch wide rear rim, that seems to have been dropped in favor of 2.15 somewhere between then and now. I guess mine isn't a single cam any more so it doesn't go in this section.
    Fran
  3. robertaccio Husqvarna
    San Diego, Ca
    Fran the TE (at least mine and another I worked on) were PHM40s with no pumper assy, they have a plate riveted in the pumper spot. Looks like the TC model and TE410 used accel pumper carbs.
  4. rancher1 Husqvarna
    WA
    You are correct sir !
  5. SM360 Husqvarna
    1999 TC 610, 2000 SM610
    2007 Moto Guzzi Griso, Ducati 900SS
    Anyone shed some light on what the spark plug gap is? I have a manual for a 1995 but cannot seem to track down what the plug gap should be set to. Thanks.
  6. SM360 Husqvarna
    Updated: .6-.7mm according to the manual. Foundd it in German. :)
  7. Sund Husqvarna
    Denmark
    TC610 1990 frame. Approx 1997 engine
    BMW R60/6 1976, Sold. YZF 250 Sold.
