125-200cc 1998 Wr360 Fork Oil Weight And Air Gap
Discussion in '2 Stroke' started by Kendric younger, May 4, 2023.
  1. Kendric younger Husqvarna
    New Zealand
    WR360
    901 Norton ,RGV500,390auto project
    Hi all
    I have a WR360 with the RWU (right way up) forks and need the following information.
    what weight oil and the air gap measurement .
    I believe with springs and spacers out and fork compressed you measure from the top of the oil to the top of the fork
  2. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    i will be rebuilding my 98 WR360 forks this week, have a Marzocchi manual for the 45/50 Magnum forks which are conventional
    will let you know what I learn if that helps
  3. Kendric younger Husqvarna
    New Zealand
    WR360
    That will be very helpful. I’ve done plenty of forks but not the 50mm magnum. Thanks. Is your copy on the magnum forms a soft copy?
  4. 2premo Husqvarna
    Northern NV
    OEM Marzocchi manual
  5. Kendric younger Husqvarna
    New Zealand
    WR360
    Rebuilt the fork in the weekend . 180mm airgap with springs out and forks fully compressed . That equals 625ml of oil per fork leg ,cycle dampner rod 5 times to bleed air .Now need to test . Only difficult part was the speration of the slider and the low leg . I was been to gentle a little more force and it came apart . Oil seal gets left in place after seperation . Other wise easy as .
    2premo likes this.
  6. 2premo Husqvarna
    Northern NV
    I got the wrong seals so did not touch mine
    but good news on your part
  7. Kendric younger Husqvarna
    New Zealand
    WR360
    Added a Husky chain saw decompression unit to the head in the weekend and made a small spring loaded lever so its easy to operate on the right side . Oh my what a difference ,why anyone wouldnt do this mod is beyond me .first or 2nd kick every time.
    NvRider55 likes this.
  8. 2premo Husqvarna
    Northern NV
    did mine with an auto decompressor, but interesting what you did there
