125-200cc 1998 wr250 help
Discussion in '2 Stroke' started by Chris390, May 9, 2017.
  1. Chris390 Husqvarna
    1998 wr250
    2010 husaberg fe390
    Hey all, did a search and couldn't find anything, although i can miss things that are right in front of me (trees, hills, etc)
    I recently got a 1998 wr250 that was a non runner. after finding that the previous owner didn't do the pickup coil plate bolts up and it was moving around in the flywheel, I got it running, but encountered another problem.
    I am not to crash hot with 2 strokes & carbs, but the problem i have is the bike is it starts & after a couple of seconds, chokes on revs, stalls on idle and fouls the plug - all withing 30 seconds to a minute. I am assuming it maybe an issue with the carb, but I am happy to hear other thoughts on this.
    what I am hoping to find out is the factory settings for the carb to make sure the needle, jets & air screw is correct. I have a 99 manual, but the 250 carb shown is different (looks more like the one on the 360 in the manual)
    thanks, & any help appreciated
  2. SmokeyExpress Husqvarna
    Canberra Australia
    2014 WR300, 1996 WR360,2013 WR125
    Hmmm. Possible a carb problem. Having said that, is the air filter clean & not clogged? The engine might just be struggling for air! Is it blowing excessive smoke? If so what colour is the smoke? White or blue? How is the gearbox oil & coolant level? From memory that model had a Mikuni TM38 or TMX38 & the float height can be a bit finicky on some (not all though curiously).
    Do check out the jetting database on here! Lots of very useful info!
  3. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    you should post this in the more vintage are
    as in Swedish left kickers
  4. troy deck Husqvarna
    Republic MO
    87 250wr 12 cr125
    kx65 ty80 rm80 kdx250
    YEA 88s ARE THE LAST OF THE SWEDISH DESIGN THINKIN ITS A MIKUNI VM
  5. 87husky500xc Husqvarna
    Dayton NV
    2020 tx300i and a few vintage bikes
    77 honda xr-75..
    Didn't he say 1998?
  6. SmokeyExpress Husqvarna
    Canberra Australia
    Errr guys this is a discussion about a 1998 wr250. It's definately Italian.
  7. Chris390 Husqvarna
    1998 wr250
    2010 husaberg fe390
    thanks for the reply. it has a new aircleaner & i have tried without the aircleaner in as well, and i can see no restrictions at all.
    it does smoke a fair bit when running, mostly white
    i think it has a tmx38 on it by all the mikuni & husqvarna parts breakdowns i have looked at, but i have not adjusted the float as of yet. i was going to pull the carb down & get everything back to factory settings so i have a confirmed base to work from!!
    i did have a look in between work & searching for info, but i havent had the chance to have a good look at it....
    also apologies for tagging this post with 125-200, i didnt notice that when i did the post!!
  8. Chris390 Husqvarna
    1998 wr250
    2010 husaberg fe390
    i forgot to add, that after starting, i can get a couple of good blips on the throttle, then after 2-3 it will start to bog down when you crack the throttle, and start to drop idle. bike isnt in gear when this is happening, and if you wait a bit (about the amount of time it takes to change the plug which is now wet) it will start again and the process repeats.
  9. 2premo Husqvarna
    Northern NV
    oops, my bad
  10. brian bush Husqvarna
    Colorado
    '93 WXC360, 2018 TC150
    A few KTMs and Husabergs.
    Chris, I have the kick starter you are looking for, for the '98. I left a message on your profile page. Let me know if you are interested. Cheers!
