Can anyone tell me what the thickness of a new clutch disc is please,I've just put the clutch pack in the bike the adjuster screw on the clutch pack is wound all the way in and the lever is adjusted all the way out. Trying to determine if the clutch cable is stretched or the clutch plates need replacing .
Clutch plate, New plate 0.112 in to 0.116 in Wear limit 0.1 in Service manual, Page 100, http://docs.wavenetworks.us/manuals//1995 TE 350-410 TE-TC 610 Repair.pdf Cheers, Dave.
Where did you get friction discs from I've been searching found a set that works well but are a lil bigger than stock
I try to always use genuine Husqvarna parts, I know they are dearer but they work. My 86 wr400 always seemed to have a weak clutch, I contacted they Husky importer in Australia, and their fix was to use one extra friction disc. Previously the clutch started with a clutch plate and ended with a friction disc. After the fix, it started and ended with a friction disc. You wouldn't think one extra disc could make so much difference but it did! If you don't have a manual, make sure to download one, saves a lot of headaches. You may have something not quite right. I know with the 400, I had to take the clutch arm off the engine because of the new clutch and clutch cable, the arm needed to be further away to take up the slack in the cable. Cheers, Dave.
