Just picked up a 95 te 350 for dirt cheap . Dropped a valve at idle . Piston is cracked . And needs a valve seat or a head . Can I throw a 410 cylinder and piston straight on it ?
You could throw a 610 engine straight in it! Seriously though, the 350 has a 57.5mm stroke, the 410 has 60.8mm stroke so you would have a VERY low compression engine unless you fit the 410 crank assuming it fits into 350 cases. Tony
Oh that sucks . I thought they might have shared a crank and just changed bore . What power at rpm was claimed for this bike ?
They both have a 63 mm stroke . They share heads and most other bits .anyone else got much yo say on either ? I think when you googled it you got the bore n stroke for a 2014 350 . They are 57.7 x 88
