125-200cc 1993 Wxc 360 clutch side crank seal direction?
Discussion in '2 Stroke' started by AdamUnderhill, Oct 8, 2019.
  1. AdamUnderhill Husqvarna
    1993 WXC 360
    1999 YZ 400F
    Can anyone confirm the factory orientation of the crank seal on the clutch side? When I disassembled, the spring side was facing out (towards clutch). Thinking maybe someone previously installed backwards thinking the spring needed to face the gear oil...?? I would think the spring side should always face the side that will see higher pressure.
  2. rancher1 Husqvarna
    WA
    I have seen this before. I usually install it with the spring facing the oil.
    2premo likes this.
  3. Long_Stroke Husqvarna
    Logan, Utah
    2011 WR300, 2013 WR144, 2020 FE501s
    1996 DR350, 2002 Aprilia Caponord
    The manual for the WR250/300 says to: "Fit the spring side towords the pinion of the primary drrive". Misspelling included.
