1984 Husqvarna 500CR Prototype???? on Ebay
Discussion in 'Vintage/Left Kickers' started by ruwfo, Jan 21, 2013.
  1. ruwfo Administrator
    NJ
    1985 250XC, 2016 FJ-09
  2. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    I don't want to sound like a naysayer but the CR500 allready existed and looking at this I see nothing that sets it apart from other
    the only guess I have is the year is not correct as listed, there has been some modification to this, obviously the lights, what, if it is as stated was the orignal fitting of parts, since the fische does not exist for "experimental" models we can only guess, besides "experimental" could also mean component testbed, as such who knows anything about any or all attempts at restoration
  3. ruwfo Administrator
    NJ
    I find the second set of shock mounting holes on the swingarm interesting, Husky swingarms are tough as nails & not that easy
    to drill thru.
    Plus, it's Ebay, so take what's written with a big grain of salt. Like this past weeks Barrett-Jackson car auction, it
    don't mean much without documentation.
  4. husqyhamm Husqvarna
    South Africa
    Quite a few 83-86 500 2Ts and 4Ts
    84 R80 GS Dakar; Victory 106.
    Please have a look at the rear hub from left side. That is not production 83/4. The rim is definitely 17". I found the exact same set-up on a mystery "84" 250CR LC 6spd which recently came into my possession.
  5. visiteur1948 Husqvarna
    france Europe
    husqvarna only
    swingarms long ! stop whelling !!?
  6. Wildebeest90210 Husqvarna
    Gloucestershire.
    Forward and back chain adjust on the drive side ?
  7. Wildebeest90210 Husqvarna
    Gloucestershire.
    It's a real real nail though, not sure it could be famous enough for me.
  8. silverstreakNZ Husqvarna
    Christchurch nz
    82cr500,76gp360,90wr250,81 420AXC
    74 tm400 , 02 gasgas ec 300
    god its in a dog of a state . and if anything that was better than they already was in use it be implemented on the next model . so the only appeal is the odd frame stamping . but then its useless because you can only restore it to what everyone else has .
    the porting of the barrell could be interesting . but then if it was better the 85 would be the same as it
  9. Kartwheel68 Husqvarna
    Newnan, Georgia
    I think this could be Billy Grossi's bike from '82, or just an '83 prototype from '82. The frame is silver, and look at the swing arm between the last lower shock mount and the axle. Its been cut, extended and has a "patch" there, EXACTLY like the Grossi 500 and was it Bigelow's 250?
    Could it be?
    There are some differences, the eBay bike has "pusher" style rear axle adjusters and this bike has traditional puller style, the eBay bike has a black painted cylinder, blue '83-'84 shocks, but none of that could not have been done later.
  10. Kartwheel68 Husqvarna
    Newnan, Georgia
    Kris Bigelow's '82 250
  11. visiteur1948 Husqvarna
    france Europe
    husqvarna only
  12. Chaz955i Husqvarna
    Macedonia, Ohio
    1982 125xc
    2003 Triumph Speed Triple
    Cool stuff going on with the Bigelow bike to get the rear suspension working correctly. I was lucky enough to see it in person as it is only a couple miles away from where I live and the owner was generous enough to show the bike and share some stories about it. I could never own that bike as I'd be way too tempted to ride it.
  13. Picklito Husqvarna
    Washington
    430, 430, 430, ,400, 175
    KTM250xc, KTM500mx, KTM440exc
    I also notice that Bigelow's bike has the trick bolt-on footpegs, while Grossi's 500 has the traditional welded version. I'd sure like to get some of those side panels... to fit the 83/84 frame and look like 82!! SaWEEEET!!
  14. 2premo Husqvarna
    Northern NV
  15. hva-factory CH Sponsor
    uk
    Husqvarna 510TE , 300WR Etc...
    Just heard that it is sold and will be coming to the UK!!!
    No I have not bought it....
    Andy.
  16. HUSQVARNA MAN Husqvarna
    OXFORD
    1983 510TC. 1989 510TC. 1984 WR500.
    1984 CR250 billy grossis works cr500
    hi ive bought the cr500 prototype and it now resides in not so sunny england,any info would be appreciated,i specialise in cr500 restos so would like to get this as near to original!
  17. Wildebeest90210 Husqvarna
    Gloucestershire.
    Good to hear. I was looking at the frame number, it looked more like ESP rather than EXP? A Spanish link? What does the engraving look like close up?
  18. husqyhamm Husqvarna
    South Africa
    Hi Hman. I also collect, restore, race 500 2Ts and 500/510 4Ts.
    I noticed your "proto" 500 for a number of reasons some of which coincide with a very odd "84" 250LC CR which came into my possession end last year.
    Nothing strange about the frame and engine no's, though much of the componentry on this machine was certainly not production 84.
    Lets start with the wheels and hubs. On my 250 its the same as on the 82 Grossi 500 machine. The hubs are what appears from a '82 125 with single leading shoe up front 17" rim at rear and no stamped production nos on either rim. Particularly the rear hub ive never seen on any normal 83/4 machines and to my knowledge also not on 81/2 machines 250cc and above.
    Can you check for number or date stamps on the rims and also post a pic of the left side of rear hub?
    Yours sincerely
    HH
  19. White Husky Husqvarna
    UK
    Sounds like an interesting project. Best of luck with the resto. Looking forward to photos. You should get lots of good info from the folks on here Kind regards Lucien.
  20. HUSQVARNA MAN Husqvarna
    OXFORD
    with a little more research ive found it to be an 83 prototype identical to grossis with a puller type adjuster on the left and pusher on the right,the frame is silver and the swing arm again identical to the grossi bike,rear rim is 18" and the cylinder has been paited black with a brush!(badly)
