1980 250cc -> 390cc, bolt-on?
Discussion in 'Vintage/Left Kickers' started by Dane1987, Apr 15, 2018.
  1. Dane1987 Husqvarna
    TE510
    Good evening!
    I cracked an engine case and will be looking at a complete overhaul, so I was wondering if the 390cc topend is a direct bolt-on to a 250cc bottom-end?
    According to the parts manual I'd say so, but I could be wrong?
  2. motomwo Husqvarna
    Imbler Oregon
    Many vintage big bore and automatics
    No, The 1980 250/390 cases are the same but the 250 crank will not work with the 390 top end.
    Marty
  3. jimspac Husqvarna
    Connecticut
    86 400WR, 82 Montesa Cota 349
    Look for a crank for a 390 between 1977 to 1980 as they all have the 71mm stroke you need. Depending on what crank you get, you may need to swap stub ends to match your primary gear inside taper and the rotor of your ignition flywheel.
  4. Dane1987 Husqvarna
    TE510
    I have found a 1978 crank. Would I be able to use the stubs from my CR250 crank?
  5. motomwo Husqvarna
    Imbler Oregon
    Yes, you can swap stub shafts. The 390 crank's clutch side will be the same as the 250's so you only need to swap the mag side stub shaft.
    Marty
