1978 CR250 clutch plate wear thickness - How worn is worn?
Discussion in 'Vintage/Left Kickers' started by Laverdaton, Jun 12, 2017.
  1. Laverdaton Husqvarna
    Anybody know what the technical specifications are for the above clutch plates - I can't seem to find the working tolerances for the fibre plates.
    My plates measure between 3.44 and 3.45mm thick.
    Is that within the wear tolerance? Andy
  2. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    ive got a tech ref sheet but clutch plate specs arnt on it:( and it starts a t 81:mad:
  3. husqyhamm Husqvarna
    South Africa
    Quite a few 83-86 500 2Ts and 4Ts
    84 R80 GS Dakar; Victory 106.
    Composite plates on those were 3,5mm thick. 0,05mm wear is nothing. How many of these in the basket? 6?
    Allu plates 1,2 mm if memory serves me right. These wear the most. Lotsa times they were replaced with steel ones from other sources. How many of these? 5?.
  4. Crashaholic Husqvarna
    Antelope Valley, CA.
    73 450WR 6spd motor in a 75 MK frame
    The Husky service manual measures clutch wear on the combined plate/disc stack. Minimum for the ML frame bikes is 26mm. See the attached PDF for reference.
  5. Laverdaton Husqvarna
    ok thanks......
