• 4 Stroke Husqvarna Motorcycles Made In Austria - About 2014 & Newer
FE/FC 14' FE250 Kick Start kit
racemx904
How does this kit work? Any good?
Got to an enduro where the temp was hovering at 30 degrees.... got bike out...... crank crank crank and nothing.... finally killed battery(brand new battery)..... luckily there was a small hill I could coast down and boom fired up..... would I be able to kick start it fine.... I know it worked good on my beta....
Why the hell would a bike come without a kickstarter....
Kits work great. It's a bit of a job but not bad if you're comfortable working on bikes. I always wanted to add one to my 501 but thankfully she always fires right up with the button. I helped install one on a 350 and it wasn't bad. Try youtube, pretty sure there's some install vids outlining them.
Many new bikes including KTM's don't come with kickstart levers so the kits are an add on item. I guess they try to drop weight by eliminating them?
https://www.ktm-parts.com/772129450...MIu5aZntPc1wIVkrfACh16swoaEAQYASABEgJO8vD_BwE
So long as the battery still has enough juice to power up the ECU yes. My suggestion is to try the electric start and if it won't fire quickly, switch to kick start right away to save the battery. My buddies 350 kicks over easily. This is only when its cold outside. Your bike should fire with the estart in warmer temps no problems though. If not, check the valve clearance.
