Magnificent 7
Discussion in 'Vintage Restoration Projects' started by dartyppyt, Aug 19, 2013.
  1. oldbikedude Husqvarna
    Honey Brook Pa.
    Looks very retro, in a trick kinda way
  2. Picklito Husqvarna
    Washington
    430, 430, 430, ,400, 175
    KTM250xc, KTM500mx, KTM440exc
    Looks ready for Carlsbad USGP!
  3. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Thanx guys!
    I modified a Honda Cr 250 chain tensioner that I can weld on towards front and I just got a Maico rear chain guide I can modify to fit in the rear before sprocket. The Cr tensioner had a so so spring on it but the stock husky spring went right on for more tension. Gonna look trick
  4. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Here are parts going to fit.
    eddychecker likes this.
  5. oldbikedude Husqvarna
    Honey Brook Pa.
    they look perfect, no surprize
    dartyppyt likes this.
  6. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    So just a fraction of time in. Got swingarm all welded up. That includes a chain guide mount, rear chain adjuster tabs and also one for the chain tensioner underneath. That swingarm been off and on this bike 50 million times to check alignment, tack weld, etc.....
    Waiting for material for brake stay arm and brake rod to fab up.
    Also, waiting on recessed Allen bolts for rear sprocket.
    If got time I think I can polish everything up to look like chrome and get a swingarm decal on.
    Lots work! Bike gonna be one of kind badass!
    DeathFromAbove and GaryM like this.
  7. ajcmbrown Husqvarna
    Metung Victoria Australia
    400WR 250WR 07 WR500 430AE 360AE
    1985 500CR Ducati Multistrada 1200S
    Nice work!
  8. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    stunning work DT
  9. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Thanx guys!
    I might have a red Husky tensioner roller but might see if DC can make me an orange one.
    Got some black Delrin coming to make a chain buffer pad.
    Thinking about sending the frame out to get powder coated in white. Silver is toast due to making fox air shock mounts and welding them on.
    Rear is coming in at 18 rear and can drop front forks down.
  10. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Actually I kinda like the red on there but I’ll have to make a new arm from 8mm to 6mm bolt size.
  11. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    i dont mind the red, it looks like its a trick part. orange will look "cosmetic"if you know what i mean
  12. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Yeah guess leave alone.
    Here is stainless brake rod I just made.
    wrx and ajcmbrown like this.
  13. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Here will be the back brake stay. Need to do some welding on back side for flange and front bushing.
    Just about ready to polish everything up and get some new bearings for front. I made special bushings up front to accept the original bearings. It had Delrin ones in it.
    eddychecker and jimspac like this.
  14. jimspac Husqvarna
    Connecticut
    86 400WR, 82 Montesa Cota 349
    Nice
  15. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Think I’ll machine up a nice new aluminum back brake lever to go with the drilled aluminum look.
  16. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Think I’ll reproduce this back brake lever but instead slots, go drilled holes and set up to use a modern black tip.
    It’s sitting high on this bike because it needs adjusted.
    These are 7602 racing tips
  17. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    waaay cool my man:rolleyes::thumbsup:
  18. jimspac Husqvarna
    Connecticut
    Replaceable pedal tips are the way to go.
  19. GaryM Husqvarna
    Austin, Tx
    1981 430cr second 430 CR 500cr
    1981 490 Maico
    Darin ! Bravo on the brake lever , perfect all Huskies could use this longer lever ! May want a pattern as was thinking of making a whole batch. Oh humm like the updated rear chain guide - so sick of the rollers wearing out in stock ones. Have someone who s ready and waiting to make some and can make them on his Haas cnc That lever looks like a late new piece ?
  20. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Gary, lever was patterned off the 83 CR 250 lever, just lil longer. Then welded on a tab for replaceable modern tip, off 2014/15 Husky, like TC 250. Then I machined pivot part to accept two bearings, pressed in for the 8mm bolt, to pivot.
    On back side is a welded on tab for a threaded for 6mm bolt to hit swing arm but as height adjuster.
    The lever part I might have a template somewhere I can get you and bearing size?
    Thanx guys!
