crhansen450
I recently bought an IMS 2.9 gallon tank for my FI 2009 SMR450. I ran out of gas once on a very short ride, although it was not full, and hoped to occasionally ride to and from work (25 miles each way).
After installing the fuel pump in the IMS tank, there did not seem to be any leaks, but I noticed the plastic that the fuel pump and gasket / o-ring would mate up to did not seem very flat. In addition the fuel pump did not want to push all the way into the tank as it was hitting gently. I tightened the bolts until they were tight. Initially there were no leaks, and the bike sat for a few weeks un-ridden. I noticed the fuel light was on, and filled up, and immediately saw a very fast unsafe leak. I got home, and took the tank off quickly and could see it leaking from the upper of the oval shaped area for the pump (on an IMS tank the bolt holes are at an angle no longer horizontal with the ground. We held a gas can and attempted to pour the gas into it. While doing this I stressed the small plastic 90 degree fitting that the fuel line connects to. I was trying to push the quick-disconnect but, had the tank up out stressing the fitting. I broke the small 90 fitting which goes into the fuel pump, when I was trying to swing the tank up out of the frame to pour the gas out the normal fill top. I really don't want to buy and entire fuel pump.
Does anybody know if just that fitting can be replaced? It does pivot, as though it is a separate part of the fuel pump, but the parts page I went to did not show it as something I can buy. In the picture it is inlet for fuel that the hose numbered 17 attaches to.
In addition my brake light is always on, and I have done some checks. Does anybody have an easy trick to figure out if the front or rear brake switch is the problem?
