Doriak
Okay, I'll go first here. My '05 Sherco 4.5i used an open loop Magneti-Marelli efi and ran great but seemed a bit "rich", I believe due to open loop efi. My new '08 TE450 has Mikuni efi and is currently in stock closed loop configuration (O2 sensor installed). I will be installing some or all of the power-up kit soon and have a question for any EFI experts here;
When you remove the O2 sensor (aka lambda probe) and install the kit's O2 plug connector, this changes the efi to an open loop and the O2 wire plug connector activates a fixed ECU map?
In closed loop, the EFI receives info from the TPS and O2 sensor and adjusts fuel injection duration accordingly for most efficient running - performance, fuel economy, emissions etc. This allows the EFI to remain "flexible" and compensate somewhat for altitude (air density) effectively "re-jetting" the fuel/air mixture as you ride (my preference) and a big reason IMO to have EFI in the first place.
In open loop, the EFI obviously gets no feedback from the removed O2 sensor, and the O2 plug connector locks the EFI into a pre-determined "race" map (non-compensating) - it runs the same no matter what - rich with maximum power and resultant poorer fuel economy.
My plan is to install the power-up Arrow muffler and spark arrestor insert, but leave the O2 sensor installed so the EFI can work at 100% capability. The bike has plenty of boost in stock trim for my riding (DS & trail) so I think the Arrow with the O2 sensor installed will be all I need to ditch the CAT, increase power and still get the full benefits from the closed loop EFI.
Am I on the right track here?
