08 TE 510 blowing fuse for lights/speedo
Afry
Bike has 200 miles on it, and obviously has a pretty bad short. Before I tear into it and isolate components and check the harness etc. are there any known issues I should be aware of that may save me some time?
While trying a trail side repair I only had a 30 amp fuse (stock is 20 amp) and it immediately blew the main fuse and killed the whole bike. So I left the 20 amp lighting fuse (lower fuse on right side) out and after replacing the main fuse it runs great but no lights or speedo.
With such few miles it's hard to believe the wiring harness could have worn through somewhere but I did notice it is very tightly installed on the frame. Seems like it could have been a few inches longer in some places.
Any thoughts?
I can't think of any tips, just look for a chafed wire, exposing metal wire. If the bike has the upgraded LED taillight, might start there. Look under the tank, that's where I found my chafed wire, the 510 vibrates alot, so if a wire is situated in the wrong position, on the frame, on a zip tie, etc, it could rub bare in 200 miles.
Okay, it only pops the fuse when on low beam. If I keep it on high beam all is good except for the bulb is burned out.
Took the switch apart and It looks like the green wire to switch is the power feed and when you are on low beam it powers the black wire so the problem must be downstream from this black wire. Where? I don't know yet.
Any thoughts?
I have the same issue on my 610
I had my stock stock headlight bulb fail and cause a short, you may want to pull the bulb and see if your short goes away.
I have a 09 te 450. I believe the same wiring than the 09, but has 07 headlight shell and speedo cluster.
A few rides back I had the same problem, no speedo or ANY lights. The fuse blown from the wires leaving the fuse holder rubbed against my subframe. The tab that pokes thru the rear fender broke and chaffed the wires... some electrical tape to insulate the conductor and some bare wire for a temp fuse.
Been gone from this site for a bit but it was the bulb. After a close look the filament post melted and bent over completing the ground all the time. I ordered an LED build as replacement so I won't be stuck riding home in the dark.
