audible
Morning all.
Starting to prep my new bike for service.
I changed my oil this weekend. Opened all three drain plugs and let drain for a few hours while I did a few things around the house. Cleaned the metal filters (had the little orange specs everyone talks about...left overs of the KTM it ate with last owner.
) and installed a new K&N oil filter. Put in 1700ml of oil. When I opened the little "check oil screw" it dribbled out about 2oz of oil...is that because as it cools the all the oil settles back to the bottom of the case.
Those of you that have the 7602 sight glass...........is that pretty accurate? Or should I just dump the recommended 1.8qt/1700ml of oil in and go ride???
The engine does not burn or leak oil and will get changed every 2 rides.
Thanks for reading.
Thanks for reading.
