Gentlemen. Searched everywhere online including the usual forums & husqvarnaoutlet.com manual archive for info on my bikes forks looking for a service manual or rebuild guide. I can't seem to find anything. If anyone here could point me in the right direction it would be appreciated. Thanks, Ed. Here's what I have: Conventional forks with 45mm stanchions. R/H stanchion has a slotted screw at the top marked "R" for rebound damping adjustment in a 19mm nut. R/H slider is marked "H" for Husqvarna on the outside. R/H slider is marked ScFMA28, 874 & 9 01 on the inside. L/H stanchion has a slotted screw marked "C" for compression damping in a 19mm nut. L/H slider is marked "H" for Husqvarna on the outside. L/H slider is marked 373, "M" for Marzocchi, 30 01 and 9 01 on the inside.
Those are marzocchi "magnum" forks. Husky used those on the full dirt line in 1996 & 1997. KTM also used them in 1995 & 1996 I believe. Husky did continue to use them on the 610 dual sports for a while. The fork seals can be the same as the 45 shivers although you may have to switch the packing washer, I have seen them both ways from the factory.
Thanks for the tip Rancher! I managed to track down the manual with that. Spent all day looking with no luck till now. I have uploaded the file as a .zip here for any other users benefit. Cheers. http://s000.tinyupload.com/?file_id=55979299138029180235
