125-200cc 09 125 WR/CR jetting thread
Discussion in '2 Stroke' started by Motosportz, Apr 25, 2009.
  1. Motosportz CH Sponsor
    Thought i would start a thread so we had one place for the jetting.
    These are emission limited stock and need the stock jetting round filed as it will not even run this way. The kit comes like this...
    Main Jet (450)-460-(470)
    Jet Needle XP-5824-01 (third clip)
    Pilot Jet (40)-45-(50)
    Piston Valve 4.0
    Adjuster Screw 1+1/2
    Starter Air Jet 80 (screwed type)
    My 09 WR125 came with a different needle than listed and is a...
    6 DEY 15-47
    I did my first ride with...
    Main Jet 460
    Jet Needle 6 DEY 15-47 (third clip)
    Pilot Jet 40
    Piston Valve 4.0
    The main issue with this jetting on my bike is a mid range flat spot. If you raise the needle (richer) the mid gets better but gets blubbery off the bottom. With this needle the best possible solution would be to raise the needle and put a smaller pilot in.
    Ultimately having the right needle would be the solution. That said i call (CPW) Carb Parts Warehouse who sells parts and loves to sell PWK carb replacements. These guys seem kinda rude on the phone and he just flat told me this carb was crap and i needed a new PWK. No thanks, I'd rather buy a $4 needle. He told me they did not have needles for them and they were proprietary husky needles. Huh? these come in Polaris sleds, Yamaha's etc. He also said they would not use the older TMX needles event hough they use all the same jets.
    So with all this in mind i went out to the shop and dug up 5 TMX needles. here is what i found.
    - Older TMX needles are the same diameter where they mount to the slide. The length is the same as well but the clip grooves are one groove lower. So physically they will fit.
    Measuring them up I find that the major dia on all the older TMX carbs needles are smaller (richer) and the point is larger (leaner). Not sure if this is what I want. As the needle is smaller and richer is also is a leaner tapper. So as you open the throttle it does not get as rich as the 6DEY needle. I will try it and see.
    Here is the 6DEY (bottom) and the 6JD-8-59 from the older TMX carbs. Note the length and clip positions.
    See how the lower needle that came in the kit gets much richer at full opening. (but starts leaner)
  2. Troy F Collins Husqvarna
    alberta canada
    wr125
    GGEC 250 Honda RC51 CBR 1000rr CR125
    The older TMX had a single taper needle...if you look real close at your pic of the new needle....you can see three area's
    The three letters on the new TMX needle are triple taper and are different (in terms of shape)
    Letters DEY indicate triple taper needle. D=1degree taper, E=1degree15min, Y=6degree15min.
    here is an example
    Mikuni needle PN: 6dey26-66
    The -66 translates to the straight part of the needle being 2.66mm in diameter.
    Other options:
    6dey26-67 = 2.67mm dia.
    6dey27-66 is a 1/2 clip richer than a 6dey26-66
    I had to look high and low for this info......and wish someone would disclose more.....I know that the Jap 125s have many variations of these needles....as well as JD
    However...... the jetting on my WR seems pretty crisp.....40 pilot.. 470 main.. needle 2nd clip from top @ 3500 to 3800 ft
    What elevation are you at...???
  3. Motosportz CH Sponsor
    250-1700 typically (45-70 temp) until mid summer when the higher elevation stuff opens up then 1500-4500 (60-85 temps).
  4. krieg Husqvarna
    Matthews, NC
    Many in the past
    '12 Triumph Scrambler
    We ran our CR in race practice (race is tomorrow) with the following:
    Elevation 520 ft.
    Temp. 88 degrees.
    Pilot. 32.5
    Stock needle. Raised a clip (richer), clip on 4th notch.
    Main. 450
    We were literally the ONLY bike that didn't sound like a wheezing, 90-year-old man. We actually had several 4 stroke riders ask us what jetting we were using (yes 4 stroke riders???). I think most of the riders still had their jetting set rich for much lower temps.
    The CR ran like a scalded dog today! My son held his own against a few 250F's and most other 125 2t's. The ultimate compliment came when he held an '08 KTM 250 SXF at bay for most of the practice heat and then stopped and let the rider go by as he waited for a YZ 125 to get closer. After the heat, the KTM rider came over to our camp and drilled us for info on the Husky.
  5. Motosportz CH Sponsor
    riding tomorrow and out the 35 pilot in with the needle one richer than stock. We will see.
  6. Norman Foley Husqvarna
    Give us a report. I can't wait to get my bike back!:banghead:
  7. BlueHusky144 Husqvarna
    Staunton, IL
    Your bike is being sacrificed for a good cause! I wish I had a 09 to test jetting. As soon as I get a tank is the day I buy a 09125!!
  8. Norman Foley Husqvarna
    Jay told me he had two '09 125's sold, only if he had the big tank..... Yours must be one!:cheers:
  9. BlueHusky144 Husqvarna
    Staunton, IL
    You are correct! He has already sold 2 WR 125's. I only ride CR 125's So far....
  10. HuskyDude Moderator
    BC, Canada
    13/TR650
    10/EC300, 76/TY175
    I know my eyes are not very good but I swear my needles were stamped BFY not DEY
    The one that came with the bike was a 6BFY43-74
    and the one that was in the CR Carb mod box was a 6BFY15-74.
    Are my eyes that bad....:eek:
    I gotta go look with a magnifying glass.
  11. Norman Foley Husqvarna
    I just looked at the stock lean needle I removed and it's a 6BFY43-74. I used my cheaters and a magnifying glass!:busted:
  12. raisrx251 Husqvarna
    Virginia
    Don't they stamp those numbers much smaller Norm?
  13. Troy F Collins Husqvarna
    alberta canada
    wr125
    Norm and Dave you are right....6BFY15-74 is the power up needle in the kit...and the 6BFY 43-74 is the lean restr. euro needle....
    I did some more research on the taper caper.....
    Needle Tapers
    Letter Taper Letter Taper
    A 0º 15' N 3º 30'
    B 0º 30' O 3º 45'
    C 0º 45' P 4º 00'
    D 1º 00' Q 4º 15'
    E 1º 15' R 4º 30'
    F 1º 30' S 4º 45'
    G 1º 45' T 5º 00'
    H 2º 00' U 5º 15'
    I 2º 15' V 5º 30'
    J 2º 30' W 5º 45'
    K 2º 45' X 6º 00'
    L 3º 00' Y 6º 15'
    M 3º 15' Z 6º 30'
    Lets use this needle as an example 6BFY15-74
    the 6 means for mikuni TMX
    the B is the taper closest to the top or clip area 0 deg 30 minutes
    F is the middle taper 1 deg 30 min
    Y is the bottom taper 6deg 15 min
    the steeper the taper(more angle) uncovers more nozzle area therefore G is richer than F....in that taper range
    sometime an additional number will come after the needle spec 6BFY15-74-3
    the 3 is the recommended clip setting.....
    BTW 15min is quarter deg... 30 min is half deg...45 min is three quarter deg...
    Jet Effectiveness
    A=Most effective
    C=Little influence
    B=Partly effective
    D=No influence
    Slide Opening
    1/8 1/4 3/8 1/2 3/4 WOT
    Cutaway
    A A B B C D
    Pilot jet
    A A B C D D
    Airscrew
    A A B C D D
    Needle Jet
    B A A C C D
    Needle
    C B A A B C
    Needle position
    B B A A B D
    Main jet
    D D C C B A
  14. Klas Husqvarna
    Sweden
    Hello Guys
    There is some problems with jetting of the new WR/CR 125 2009.
    It is very difficult to solve this without use the new parts that are dilivered from Huskyfactory. There is a tread here at huskycafe.
    The new powervalves solve the problem. We have tested this weekend here in sweden.
    The bike run great with sock jettting.
    Klas
  15. Norman Foley Husqvarna
    I kind of figured that the upgraded parts would fix the problem. Thanks Klas!:thumbsup:
  16. Troy F Collins Husqvarna
    alberta canada
    wr125
    Well doggie............:applause::applause::applause:
  17. Troy F Collins Husqvarna
    alberta canada
    wr125
    Klas...If I may ask....having run the new parts.....what can we expect..?????
    is the exhaust different.....and what about the silencer...???
    Big thanks for browsing this thread...and chiming in :cheers:
  18. Motosportz CH Sponsor
    Rode my bike in an area with very steep hill climbs and was very disappointed. Played with the needle all over the place and made little to no difference. Falls flat in it's face in the mid, bottom crawls pretty good and top end rips but getting to the top end past the huge hole in middle is very hard and when it drops off again you beck in the huge hole. On up-hills I was fanning the crap out of the clutch to make it up. Something is not right. My 04 did not do this.
    What is the power valve mod / upgrade? Maybe I need to stop chasing the jetting and fix the power valve.
    - Love the bike hate the gigantic hole in the mid range.
  19. HuskyDude Moderator
    BC, Canada
    13/TR650
    10/EC300, 76/TY175
    Glad I'm not the only one disappointed with this 125 when it comes to hill climbs. Which there are way to many of around here.
    I think I'll park mine for awhile a start practicing with my trials.
    We have our national come up in May and I haven't rode it since last year.
  20. Norman Foley Husqvarna
    For some reason (Power Now?) my '09 doesn't do this. Hills I'd be feathering the clutch on my '02, it motors right up. I'm still prefered power up jetting spec. Not that I don't have some midrange burble, but not the big hole described by others.
