125-200cc Jetting Specs With RM Needle/TMXX
Discussion in '2 Stroke' started by dartyppyt, Oct 6, 2010.
  1. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Please post your settings only:
    09 WR125
    Carb: TMXX 38
    Elevation: 900- 1,000 ft
    Slide 5.0
    Needle: 6CHY16-62 (04 Suzuki RM125)
    Main: 460
    Pilot: 45
    Spark Plug: BR9ES
    Air Screw 1 1/2 Turns Out
    Temperature: 70 degrees + Okay, Clip in middle postion #3
    60 degrees - I am using a 1/2 clip shim under needle clip in middle position #3
    50 degrees - 1 full clip move richer #4 slot
    Fuel: 93 Octane/ 3oz. Per Gallon Maxima Octane Booster
    Oil: Amsoil Dominator
    Ratio: 40:1
    Mods: .3mm Base Gasket Only From Husqvarna (I recommend, I do notice a slight roll on throttle difference for $4.75).
    Power Valve Spring Kit (Using Stock/Silver Spring, Bolt about 3/4 up in slot).
  2. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Crille 74's Settings
    Factory 144 Kit
    Hgs 144cc pipe and silencer
    5,0 slide
    Rm needle 2clip position
    45pilot jet
    460main jet
    Spark Plug Ngk BR9EIX
    powervalve in 3/4 from top
  3. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Don't forget to post your tuning specs here with the RM needle.
    Some day will try and have this moved up to a sticky for other riders.
    Thanx!
  4. BillO Husqvarna
    Ontario, Canada
    Can we add this to the CR/WR 125 Index Thread?
  5. MattR 2T Forum Clerk
    Temperance, MI
    WB165, SM610
    Yamaha FZ1
    Added it today.
    See Carburator Topics > Mikuni TMX section.
    dartyppyt likes this.
  6. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Thanx Matt/BillO
    Darin
  7. mac37 Husqvarna
    Oregon
    These were the settings I used at the PNW Get together in Bend, OR
    09 WR125
    Carb: TMXX 38
    Stock Pipe with FMF SA
    Elevation: 4000 to 5000ft
    Temperature: 40 to 60 degrees
    Slide 5.0
    Needle: 6CHY16-62 (04 Suzuki RM125) middle position
    Main: 460
    Pilot: 45
    Air Screw 1 3/4 Turns Out
    Fuel: 93 Octane
    Oil: Amsoil Dominator at 32 to 1
    Twin Air air filter with No Toil
    Bike ran great very little spooge.
    I will try the Suzuki 42.5 pilot
  8. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
  9. crille74 Husqvarna
    Sweden
    Husqvarna cr 125 2014
    Crille 74's Settings (New)
    Factory 144 Kit
    Hgs 144cc pipe and stock silencer
    5,0 slide
    Rm needle 2clip position 6CHY16-63 runns a little fat in the middle whit the 62 needle
    45pilot jet will try my 42,5 this wekend
    460main jet
    Runns alot cleaner in the middle rpm whit the 63 needle.
  10. BillO Husqvarna
    Ontario, Canada
    Crille,
    What is your elevation and approximate operating temperature?
  11. crille74 Husqvarna
    Sweden
    166 meters over sea and +10-0 celsius
  12. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Well if I did my math correct, that is 32 to 50 degrees and 500ft above sea level.
  13. Johnnymannen Husqvarna
    Sweden
    hello guys! I have a question: I bought a 125 WR for my son recently, and it had the old TMX with square throttle. Nr 3 throttle. The bike didn,t run too well with this so i just put on my Factory TMXX from my 300 on it with the RM needle in second slot and throttle nr 4, and it was a great improvement. BUT i have a problem, and that is that the TMXX is about 10mm too short for the airbox. It just lines up to the hoseclamp. Does anyone of you have an easy solution to this?
    Johnny
  14. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Just posted on other thread, your fix. You will need the 5.0 slide for it to run the best. With the WR ignition, it is going to like a little richer pilot, probably a 42 or 45ish. The CR ignition likes a 37.5 to 35ish down. Some of the higher elevation guys are even further down.
    Note: That carb likes a front, carb divider as well. It helps on the lower circuit of carb,throttle response.RB designs does lot of these carbs. They are really good! Others can chime in that used them. It is well worth the money.
    I also am a big fan, of Walt's powervalve springs. I like the stock/silver combo, adjusted about 3/4 up.
    By the way, what is the number on the needle? Makes difference on clip position?
    Stick with it till you hit the mother load!
  15. Johnnymannen Husqvarna
    Sweden
    Ok, thanks Darty! The bike is a-08 model, but maybe it should have a #5 slide too? The needle is a 6CHY12-62, now in 2nd slot from top. We have around 10 degrees C here now, sealevel. What do i do with the airbox connection? Longer intake rubber? Is it available?
    Johnny
  16. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Use the 5.0 slide, that needle has one of the sharpest tapers from throttle opening, to opening the main. The 5 slide gives it the proper air mix. Then you'll be 460-470 main. Then mess with pilot size/needle clip position.
    Also, you can stick another gasket in between the boot and reed block, and keep the one between the reed block/engine.
    If it has the V-Force 2 reed block? Do you know what the reed limiter plates are set on? Low or High?
  17. Johnnymannen Husqvarna
    Sweden
    Ok, maybe i can cut the slide a bit then. I have a 410 main in it now, but after what you say i better go up to around 460 then? Even with that fat needle?
    I haven,t checked the reeds yet, but i will check when we change piston which is high time to do:=)! I will go for a Wössner i think. I think i gave you the wrong needle number before! 6CHY16-62 it must be, not 12-62!
    Johnny.
  18. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Johnny,
    Some of the husky shops have them laying around, from power up kits. Just a thought? Post a pic from the side of the reed housing and i can tell you what reed block you have in. V-force 3 is black. V-force 2 is grey. If you do have the V2 and it is set on high. You won't get the throttle torque as good on the bottom.
    Thanx
    Darin
  19. Johnnymannen Husqvarna
    Sweden
    Ok, i check when i get home which colour the reedblock has! I don,t think the guy who raced it before has done any mods except the HGS exhaust. I,ll see how much i get done this evening. I will take the cylinder of my ported Honda CR 500 to rebore it before the iceracing season begins=). That bike doesn,t have any torque problems! Haha! Thanks so far Darin!
    Johnny
  20. Johnnymannen Husqvarna
    Sweden
    Darin! I checked the 125 and it has the grey reedblock,V2 then. i haven,t taken it apart today, but i guess i see what you mean with low and high setting when i have it in my hand. It,s been work on the 500 this evening.
    Johnny.
