50MM Marzocchi Fork Protectors
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by dartyppyt, Apr 26, 2010.
  1. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    What Model/Year Honda crosses over to the Marzocchi fork protectors? It appears that an 09 Cr450 will work? Looks like you have to get a front brake line clamp?
    Would like to go White or Red?
    Thanx!
  2. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    Do tell....I'd like something other than bleahk.:D
  3. husk husk Husqvarna
    UK
    Honda CR/CRF from 1995 - 2010 fork guards will fit!
  4. husk husk Husqvarna
    UK
    As will 2007 onwards KTM fork guards
  5. fury1 Husqvarna
    ma.
    they will fit,but they use a different style clamp for the brake line than the husky
  6. husk husk Husqvarna
    UK
    Buy the clamp from honda and use that. IMO its better than the husky one anyway
  7. husk husk Husqvarna
    UK
    Heres the bits you'll need to use the honda clamp;
    #45461-MEN-000 Clamp A $4.05
    #45462-MEN-000 Clamp B $2.97
    #90113-KZ3-000 Flanged Bolt x2 $1.62 each
  8. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Thanx guys! I am going to order the parts next week and the fork protectors (White).
    We should Archive this under parts that interchange?????
  9. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Last night I got my new 09 Honda CRF450 fork protectors from UFO. I'm still waiting on the brake clamps from my local Honda Shop. I installed them and I think they look real sharp. They bolted right up and fit perfect. Dave @ UFO said that the red doesn't match and is way too light in color. They held them against the Husky shrouds while I was on the phone. Thanx for the tip on these and they look sweet!
    Typpyt
  10. fitness2go Husqvarna
    Seattle WA
    Throw a picture or two up!
  11. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    I will as soon as the Brake clamp gets here.
    Typpyt
  12. husk husk Husqvarna
    UK
    The only reason I knew they fit is because we bought 50mm Shivers for our CRF, and I knew that whatever bike the forks were for, they came with Honda fork guards! Probably for the fact they havent changed the design since like 1994!
    The only issue you may have, is the brake clamp. Looking at our husky front hose, from memory it looks slightly smaller than the Honda brake hose. The honda hose is nissin whereas husky is brembo. Easy fix would just cut a small part of black hose, slip it over the brake hose and then in the clamp.
    Let us know how it fits.
    Lewis
  13. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Just finished the job last night. The brake hose clamp is designed to clamp (Pinch)the plastic bracket on the protectors. If you go through the bolt bins at the cycle shops. Choose two bolts that have the built in spacers to fit tight thru the plastic holes so that you can mount the clamp towards the wheel side. The clamp now holds the line tight with no mods.
    Will post pic first of week.
    The white really look sharp!
    Typpyt
  14. husk husk Husqvarna
    UK
    You've got it wrong, you need the specific bolts coz the clamp goes to one side of the plastic lug and the bolt goes through.
    Heres the pic;
  15. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Great,
    I have it right then because that is the way I did it.
    It clamped fine on the brake line. Was not loose at all.
    Typpyt
  16. motosapiens Husqvarna
    kuna, idaho
    really? why 2007 onwards? 2004-2007 ktm guards are identical (and interchangeable with 2008+ guards.
    I might be tempted to put some ktm guards on since they cover alot more. Makes them harder to clean if you ride in mud alot, but provides significantly better protection from rock dings. I've had to fix a few of those over the last few years.
  17. husk husk Husqvarna
    UK
    Yeh I guess pre 07 will fit too. Only reason I said 07 onwards was because I've seen a few people with the 07 ones on Honda
  18. husk husk Husqvarna
    UK
    Ah sorry, I mis-understood what you meant!
    Glad it worked ok, get some pics up!
    Lewis
  19. huskyte310 Husqvarna
    Westchester New York
    09/te310
    Try 06 tc450 husky stock fork guards they rap around the sides. You will need that brake line clamp too.
  20. MXRider Husqvarna
    Virginia
    None
    2009 Yamaha YZ250F
    sweet.
    I think Im gonna try to find some light speed carbon ones.
    (they are way cheaper for a CR than Husky specific carbon fiber from other brands)
